I use the Gorilla glue as well with a healthy dose of water. Spread glue sparingly on one piece and flood the second with water (and I mean FLOOD). clamp together....white beads will appear quickly. The glue will be set in about 1/2 hour when it looses it's "stickiness". Use a putty knife to remove the "beads". Don't wait!!!!! If you do, the glue will tear out some of the foam along the joint when you try to remove it.
