Pushing plastic through another material (typically plastic through aluminum) you'd call that a "Push-Thru". It's very easy to do.. But, I use a method I think that can be simplified.
I first pull up Flexi (typically my vector interface for 90% of jobs). I get my aluminum panel, and make a copy of it for my plastic (so, I have 2 identical images). I then, take my aluminum vector and grow it .03125" with straight edges. Then, I figure out what tool I will be using (typically 3/16" or 1/8" if it's really small lettering). Assuming we're using 3/16" I will create an outline of .09375" with rounded edges, then create an inline of .09375 with rounded edges. This will compensate for the bit on the edges of the plastic.
I then grab my plastic vector and inline that .09375, then outline it .09375. This will compensate for the aluminum. Then, create the flange (typically .375") I will grab JUST THE FLANGE and outline it .375" rounded corners, then inline it .375" with rounded corners.. That makes everything round and smooth.. Export to Enroute and toolpath it. For the flange, I try to keep between 1/8" and 3/16" for height.. This way, it's not easy to break and it won't create too much of a problem when applying clips.
Wow, that sounds confusing..
What methods do you use?
