Thanks!Wow - lookin' good!
Yeah, I sort of jumped the gun on the routing since the texture was my biggest concern. For this test run I'll have to paint those edges and carefully sand them back down.Given that explanation, it seems the best way to reproduce the worn out sign would be to use plywood. No guarantees on what the inner layer will look like, so it may or may not have the horizontal "boards" of the original. And given the lower quality of lumber nowadays, it will probably be crappy looking wood.
I think you could do this with MDO. Using your vector drawing, make a paper pattern and pounce it onto the primed MDO. Hand paint the design, probably in several coats with adequate drying time. Make sure to go outside the outer lines ("bleed"). Then do a very shallow routing of all the outside of the design, just taking away the resin laminate and adhesive, and exposing the underlying top layer of the plywood. If desired, also route the separation of the "boards" the original had.
If you want there to be wood grain showing through the paint, you'd have to use plywood without overlay. However to get to the next layer of plywood would be probably almost a 1/8" depth.
Thanks! More photos coming soon!Looks awesome!!! Like you said, at this point, who cares about the money, what a FUN project!
My vote is for faded over Pantone.
Cool. Thanks!The prefinished white is usually okay. Since the goal is to replicate aged paint, it would probably be okay to just distress it and not put another coat of white over it. Unless they opt to make all the painted areas look like they were just freshly repainted.
Just whatever I bought from GSG a decade ago. I'd be hard pressed to figure out who the manufacturer was. For new sheets I would simply try to source the best quality MDO available. (I don't mind if it has knots -- I actually prefer them -- but the higher quality stuff might be less likely to warp?)What kind of MDO are you using? I think a lot of us here are surprised that you are using a CNC to strip off the paper liner to achieve the weathered effect.
I know that you are fairly new to this, but, there are at least a dozen options where you could have built the whole sign in one workday, and still have it pass inspection of the client. (of course, painting would take a few more days). Sandblasting and HDU would also be at the top of my list.
Oh, I missed your first question. For the past 26 years, I've always been the vinyl guy. Decals, wraps, banners, all the usual things.What kind of work do you normally do? Do you do a lot of actual "painting"?
Oh wow. that looks great! I'm guessing the logo / letters are sandblasted. Surely that wood grain texture takes a great deal of time to hand carve. What's the size on that? Looks to be about 24" x 12".This is sandblasted and hand-carved HDU - When it first came on the market 35 years ago, I stopped using wood almost entirely and focused on texturing HDU to resemble wood with 100% success as opposed to wood projects.
Wow, very cool!Small HDU signs like this were my bread-n-butter. (Note: No CNC was used).
Something that crossed my mind was -- handing over some pre-stenciled sheet of HDU and a grain screen to a local sandblaster could help make my sign (Obviously that's a pipe dream, now that I'm researching it). After watching a handful of YT sandblasting / technique videos -- sandblasting signs IS a whole thing in/of itself. And a fair bit of work to boot (especially in terms of using real wood / joined planks). Videos make it look easy when they're performed by the seasoned pros. Very cool stuff.Sandblasting signs is an art in itself. It could take a novice hours, weeks, months, or never, to become good at it.
Yes, there are wireframes to make the grain effect. I made my own where I could blast 3x8 foot sections without moving it.
I also made an air-tight room in my shop just for sandblasting HDU with aluminum oxide, as the oxide can be reclaimed and recycled hundreds of times, whereas silica sand is a one-time deal.
There are some members here who attended a Letterheads Meet at my shop in 2002 who got to use the blasting booth.
Pace yourself carefully when adding new "methods" to your portfolio.
