HOW TO DISABLE MUTOH INK MONITOR
poligrafika
Hi
Can some know the way to permanent disable the Ink monitor on Mutoh 1204 and 1604.
Or someone offer a solution to disable smart cards.
I want to put ciss system on both printers, because Ink cartridges are getting expensive to work.
There's usually some Russian guy hanging around here who can do it for you for a cost. Have you looked into using the Mutoh CISS?
Subysti
I have a 1324 not in use anymore that I had reprogrammed to disable the ink monitor. If the boards are the same you're welcome to the entire printer if you come get it.
