How to exit service mode on ROLAND Truevis LG-640
darrellcarpenay
Recently Roland LG Truevis installed by my tech, but it is stuck in service mode. Can anyone assist with exiting service mode? Power on and off with switch doesn't work.
SGC
I’d take that as a blessing, unless modern service mode causes features to go away.
Jim Hancock
Old School Technician
Suggest turning the printer off with both power switches and unplug for 15 minutes. Restatrt and see if that does the trick...
darrellcarpenay
Update from the tech is that the machine always has SERVICE MODE available. The auto-maintenance / cleaning on the LG640 is quite regular also - every time you power on there is a cleaning and you should shake white ink daily.
Power on and off clears service mode.
Stormy7
Hey, how you finding the LG so far, did you just get a new update on the first ?
Cheers
Alex
darrellcarpenay
Cheers
Alex
The LG is my first UV printer. Roland apparently had some issues with he inks and that seems to have gotten resolved for the most part.
I've found that the maintenance on the printer creates a lot of waste ink, which I have never seen in the latex or solvent printers I've had. I believe the waste is more with the white ink option, so I switched to double cmyk for speed instead. So far, I think the waste ink and time for maintenance has decreased, but ink wastage is still concerning.
The print quality is good, but I just can't accept that the black ink just isn't black enough. Compared to solvent and latex black - this black is like a very dark grey. Roland needs to fix that.
The speed for 2xCMYK is fantastic, and the fact that it instantly dries is a huge plus - if you're going to blast out prints really fast, you might fall in love with this machine. For regular speed, I find the quality to be good, but I've noticed some minor banding which could be due to some adjustments required on my end.
The smell of the ink can be overwhelming - latex and solvent are way less obnoxious.
I haven't been able to find any media profiles for the printer online. You're stuck with the default profiles for now, and within those profiles aren't many options to adjust either.
Print cut option is smooth although I don't use it that much - I prefer to print and cut separately.
I would like to think that Roland is working on the issues with the printer to fix them. Let's see how that goes, but for now, I'd recommend you go with a VG3.
CarlosCee
My shop got a TrueVis VG3-540 a year ago and as I've been left as the only person to figure out how to use it. Months ago, after my own experiences and online research, did i find out about the ink waste from all the automatic cleanings and how much ink is used to do said cleanings. Despite showing this information to my manager, I am still blamed for wasting ink somehow. Not a fan.
cornholio
If i were you, i would leave it that way. You can enter service mode, without having a Peck2 access. If you wants to disable it, you need to toggle bit 1 in system switch page 10 to zero.
CustomThunder6
But you can enter support mode for calibrations and Jwithout specific service mode settings for repairs
