How to get RIP to read material in FlexiPrint
ddarlak
Go Bills!
I use FlexiPro 10 but I RIP to my HP 315 with the FlexiPrint12 that came with the printer.
It used to auto read the material size and material type but at one point it asked me if I wanted to keep doing it and I selected the wrong answer.
Now every time I go to print something I have to the little printer icon to size the roll and change the preset material type to what I loaded. I cannot find where to set it back to how it was working before when it auto read from the printer.
Anyone know where this setting is?
eahicks
In Production Manager, Click Setup>Setup Properties, then check off "Automatically apply loaded media".
ddarlak
Go Bills!
didn't work.
It used to be the material I selected when loading the printer would load into the RIP, now it defaults to a material that was in when i accidentally clicked what ever i clicked...
eahicks
didn't work.
Well that's the only place I know of that will do that. There will always be a 'default' material setting in the Default Job Properties, but having that one box checked will always cause a pop up after you load your material and select it on the printer. It will ask if you want to load this material and size for the next jobs you rip. So make sure it has a check and then hit APPLY afterwards.
GaSouthpaw
This might be a kind of a sill suggestion, but if you're certain the printer supports that kind of bi-directional communication, make sure all your connections are good. If it's via network, make sure it's allowing the communication. If it's via USB, make sure you're using a cable that allows it.
