How to manually remove air form ink tube from Roland Versa Camm Vs-540 ?
schilderpixner
Hi everybody,
Does enyone how to remove manually air for Roland Versa Camm VS-540 ink tube ?
I change the dumpers and lloks like black and Magenta doesn't fire..
Thank you very much
CS-SignSupply
Until you pop the valve and side of the damper to then fill the damper chamber of the head with ink and ruin the head, if not more ...
There are proper ways of doing this but I would recommend a service tech help or perform the following...
Verify ink in all cartridges - Clean or replace captop assembly with new OEM part - perform Choke Clean
Doing it on your own and you risk the $2500 printhead plus other parts? Pay a tech to clear out the air for what, $250-$500 depending on drive time/labor rate/etc....
  • Agree
Reactions: 1 users
mfa53
Should be videos on YouTube of pulling ink with a syringe. Doesn't have to be your exact printer. Just do not pull too fast as that can damage the head so pull slowly.
I searched for hours yesterday but couldn't find it, so sorry. Maybe I'm searching in the wrong way, I wouldn't have written to this friend if I could find it, I'm so sorry :(
netsol
the process is remarkably like bleeding brakes. find the right adapter, hook up either to the drain line (going into waste tank) or, more realistically, to the hose coming off of each captop
pull SLOWLY (not wasting ink or damaging the internals of the printhead)
much like bleeding brakes, you will reach the point there is no air in the line
i really love the tapered syringes solventinkjet.com sells, but, when you reach the end of travel, the ink will tend to backflow
you should certainly order at least one of the tapered syringes, it will come in handy in the future, just not for this job, i think
Signarama Jockey
Had a big bubble in one of my yellow lines. I've been running cleaning cycles, swapping cartridges, giving it time, and nothing was working. That brought me here. Did the choke clean and that did the trick. Thanks for the info!
guillermo
what is a choke clean? never heard of this term, and I have been using rolands since 2005.
guillermo
to take air out of ink lines, I remove the cover, then carefully, disconnect the 2 hoses coming from the cap top to the pump, use a black paper clip to clamp one hose, then use the syringe in the other hose, you will pull ink from only 4 lines of ink, making sure air comes out, then switch, clamp the holes you just pulled ink and insert syringe in the other hose, repeat until you get the air out, just make sure the print head is at home position to seal the cap top with print head.
Signarama Jockey
I use a Roland VersaCamm VS-640i. The manual says:
"Perform this cleaning when printed colors are unstable or uneven, e.g., when color density is inconsistent, even if the same data is printed with the same settings. This will stabilize the output colors by agitating the ink. Light choke cleaning consumes a lot of ink, and overly frequent use may damage the print heads themselves. Avoid performing this operation more than necessary."
It can be accessed through the following menu path:
MENU > SUB MENU > INK CONTROL > LIGHT CHOKE CL.
guillermo
Thank you very much.
  • Agree
Reactions: 1 user
guillermo
by the way.... my RE640 does not have that option.
