graphicsphere
Hi I have a VP-540 that I need to replace the cutting carriage and print carriage L-bearing blocks since its binding and is really hard to move freely along the rail.
So I'm trying to find a good how to video or instruction manual so I can see what parts I need to remove first before I replace the L-Bearing Blocks. Is there one bearing block for the cutting carriage and one bearing block for the print carriage? How many bearings do I need to replace and what are the Roland part numbers so I can order them?
Can anyone explain how the L-Bearing Blocks are removed off the rail? Do I need to remove all printheads from the print carriage first? What else needs to be removed first?
Thank you
Thank you
