How would you construct and mount this sign!
dynaminator
I have a client who wants a sign just like this. How would you construct this? Also pictured is the surface to be installed on, I am told it is exposed aggregate concrete. How would you install to this surface. Thanks!
John_Smith
Enjoying retirement in Central Florida
Whoooaaaaa the "exposed aggregate concrete" is only a veneer . . . . you should pass on this and run, Forrest, Run.
Just out of curiosity, you are in Wisc.? What size panel? How high off the ground? yada yada yada.
Texas_Signmaker
Very Active Signmaker
If you're asking these questions you shouldn't consider installing it. You have to have something structural to anchor to and get engineering.
  • Agree
Reactions: 1 users
The willow sign should have guy wires on it.
As for building it: Use .090 aluminum, bend the 4 sides to 90° for whatever your return will be and then carefully weld the other side on. Insert a heavy duty eye hook in the top outside corner. Powder coat it.
As for mounting, ya need more input on the column itself, but you'll need guy wires also.
  • Agree
Reactions: 1 users
John_Smith
okey dokey I will fly away like an Eagle and have my installer do it for $500
Even if your "installer" installs it for you, YOU will be on the hook for anything that may happen there afterwards, correct ???
How much faith do you have in your installer's ability to make sure it won't come down two weeks later and hurt someone?
  • Agree
Reactions: 1 users
dannyd1962
Remote Freelancer
First off, I would pass on this project as it is, and offer a totally different sign / installation......
  • Agree
Reactions: 2 users
White Haus
Not a Newbie
Yeah, and if they're only charging $500 to install this............... I wouldn't have much faith in their methods.
  • Agree
Reactions: 1 user
kcollinsdesign
Old member
$500 would probably cover the fabricated steel mounting plate (with welded internal arms to support the sign), appropriate anchors to mount the plate (may need at least one through-bolt), and a guy wire assembly with turnbuckles (two in this case). Will take at least a bucket truck and an extra installer about 4 hours (around $800). Designing the installation, including a survey, and project management, will be at least four hours, so figure around 5 hours (say $500). Then you need to add permit acquisition (add another $125). You will probably need stamped engineering drawings (probably another $500 or so).
I would guess the total installation would cost in the neighborhood of $2425 (plus the cost of the permit). Add the cost of the sign and drive time for the total price of the sign installed. We would give a one year warranty, and sell an additional 4 years for $500.00 (you will be out there at least once to tighten the anchors and turnbuckles).
If you have a guy that will do it for $500 make sure they contract directly with the customer (and sign a liability release waiver when you hand your customer the sign). Note: We would not do that; I've been doing this too long and over the course of 40+ years have become rather risk averse...
  • Agree
Reactions: 3 users
dynaminator
He's a great guy with an impeccable record
  • Informative
Reactions: 1 user
kcollinsdesign
Old member
The attorneys for the plaintiff's insurance company are bound by fiduciary duty to not give a rat's ass how great a person the defendant is. If your sub-contractor is working under contract for you (verbal or in writing), you will be the defendant. You will need to take additional action to recover from your sub-contractor.
Typically your insurance company will require a current and approved Certificate of Insurance be on file when working with subcontractors (we also check licensing, criminal record, and run a credit report). You will also need a written record of approval from the landlord (not the business owner). Your books must be in order before they will accept the claim. Insurance companies will do everything they can to weasel out of a claim, especially if it is a big one (for smaller claims it may be less expensive to settle before firing up the lawyers; expect your premium rates to go up; in some cases they will drop your coverage or shift you into a more comprehensive, and expensive, plan).
Please do not take this as comprehensive advice. I am not a lawyer, and these are just some things I am mentioning. Consult with an attorney (and your accountant) before hiring subcontractors.
  • Agree
Reactions: 4 users
JBurton
Signtologist
Nothing to do with this headache of an install, but you bringing up extended warranty reminded me of this. I read a case that made it to the supreme court of Arkansas (I know, it sounds like a joke), where a sign company sold a message center that never worked right, along with a 5 year warranty. The church eventually sued them, but had waited too long. Their problem was bringing the suit against the sign company under the UCC (universal commercial code), which includes a 4 year statute of limitations for sales of goods. Since the contract for the sign involved more costs for goods than for services, it was not considered a construction contract. At any rate, my mind was blown that something like a $150k message center could be sold, unsupported, fail, and as long as nobody sued in the first 4 years, it doesn't matter how long the warranty period is for. https://law.justia.com/cases/arkansas/court-of-appeals/2025/cv-23-702.html
  • OMG / WOW
  • Agree
Reactions: 1 users
kcollinsdesign
Old member
Warranties are part of the sales negotiation for digital signage. I have been lucky in working with quality fabricators. Usually the customer will be happy with the manufacturers warranty along with our standard one year parts and service warranty. I make sure I talk to them about it, though, and that they understand the sign will need service throughout its life. It's rare that I sell a shop warranty these days, but it is how I open up the conversation regarding service and maintenance.
When I got into this business service contracts were lucrative. All electric signs had lamps and ballasts changed regularly, or occasionally needed replaced neon and transformers. We would make a route and use it as filler work. Sign companies were often multi-generational (why else would you get into this business?), and stayed around for years. Things are different today.
  • Agree
Reactions: 1 user
Hal D
Does anyone else on here remember going out on "night patrol"? Back in the 80s and 90s when I was a bit younger, I'd go out on night patrol a couple times each week with my Instamatic camera and tape recorder to check around and see who had sign and parking lot light outages. I would give all the info to our Service & Maintenance Manager and he'd make the phone calls to the customer to let them know that their sign was partially out or totally out. If it was a strip center or big box store, he (Ted) already had those contacts in his Rolodex! This is so funny, yet nostalgic talking about today, LOL! Between Ted and I, we managed to keep the bucket trucks and crews pretty busy when they weren't installing signs and I made an extra 10% commissions on each service call completed. Those were fun days and good memories!
  • Agree
Reactions: 1 user
kcollinsdesign
Old member
I still do that. Modern electric signs need less service (on the flip side those old signs last forever). It's unlikely, however, that the majority of signs these days need to last much past 5 years. Brands are constantly changing and restaurants and small businesses pop up and close all the time.
We used to stock our trucks with ballasts, transformers, and fluorescent lamps. Now we stock them with power supplies, controllers, and modems.
JBurton
Signtologist
We called it 'riding lights', but anymore it's calls because all their led sticks fell out of the sockets and are in a bundle on one side of the sign...
