HP 365 Continues To Print But The Paper Stops Feeding
JamesLam
The 365 has decided to protest. Sometimes it acts up and sometimes everything is peachy.
It will feed a job for about four or five inches and stop. But it continues to print on the same ban. Of course there is a big mess of ink to contend with.
The first image is from the other day where I did not catch it. It printed the same band for about 5 minutes before I caught it.
The second and third image are from this afternoon. I ran two jobs earlier without an issue and then it happened again.
Any thoughts?
balstestrat
Problem Solver
Need to figure out what's happening. Is the drive roller still moving but material slipping? Is the drive roller motor moving but gear slipping? Is the substrate input stuck?
  • Agree
Reactions: 1 user
Reio
I had similar on L26500 which was caused by too strong vacuum setting on certain media.
  • Agree
Reactions: 3 users
JamesLam
Cleaned everything, including OMAS, vacuum ports, rollers, etc.
The issues occurred when running the HP Satin Poster paper roll to roll. I was having some scuffing so I increased the vacuum. The first few batches ran perfectly then the problems started. So I dumped the profile, and started from scratch. Ran a few outputs without a problem and then it started acting up again. Fortunately I caught it before I had ink everywhere.
Now one thing I noticed was that the rollers where the paper is in contact where not moving but the rollers where there was no contact where moving. This leads me to think that the vacuum was too high and the feed and take-off where insufficient to draw the material through.
Yesterday I ran HP Pro Satin HW Paper and some heavyweight canvas and had no issues at all.
MikePro
wondering if the material finish and the vacuum are creating too much friction vs slip for the rollers to keep up with the material feed
have you tried burning enough material prior to starting print, to get the material on the takeup roll? maybe a little "tug with your rub" might be the solution.
...plus the tension from the takeup reel would also allow you to print with less vacuum
JBurton
Signtologist
I've had the same thing happen, only on a very heavy mesh roll that was printing way too many passes. Between the vacuum, the slow advance, and the heat, that sh*t stuck and piled ink beautifully.
Tried babysitting while tugging, going straight to the takeup, heavy clamps, only fix was reducing to 10 passes.
JamesLam
Ran some vinyl this afternoon.
The first batch advanced as it should but nothing printed. So I cancelled that. Checked artwork, made sure there was nothing that shouldn't be there and ran it again.
Second attempt, eight rows of 2" x 3" decals. Referring to the pics below the barcode and the first four rows where out of focus. By the fifth row everything came back into focus. Despite the blurry barcode and lower marks the cutter was able to read this mess and cut away perfectly.
Third attempt, thinking it may have resolved itself, or I undid what I didn't know I did. No luck, same out of focus printing.
cornholio
Habe you cleaned the feed roller rubbers?
Start feed roller rotation in service mode, open the window and remove the two print platens for easy access.
  • Agree
Reactions: 1 user
JamesLam
Good idea but a few questions.
How do I get into the service mode? Seems I need a pass code, unless I'm looking in the wrong place.
Recommended cleaner?
