HP 560 error 21.5.03
JBurton
Signtologist
From the PC side:
The part that advances the printhead maintenance cartridge roll is blocked.
From the printer:
RackEngage: unable to disengage rack.
So this started when my maintenance cartridge was at the end of it's life, but since I was waiting for one, I just power cycled and it would continue printing. In this week long period, it asked to clean and lubricate the carriage rail. I asked a less experienced/caring individual to do that, as the printer walks you through it just fine.
Got the maintenance cart in, popped it in, thought everything was solved, but it stopped mid print with this error.
Looking at the encoder strip, it had some oil on it, so I'm guessing its just dirty, and the printer is losing place and throwing this as an error.
I'm about to pull the maintenance cart and make sure there's nothing foreign in there.
Any tips on cleaning the encoder strip other than water on lent free cloth?
JBurton
Signtologist
I guess these are getting a bit long in the tooth of the test rat to dig in on?
I'm not against replacing it with a 630 or something, but I just did smk3 on the old girl.
JBurton
Signtologist
Well I cleaned the strip with water, ran some test prints, all was good. Ran a longer print overnight, it did not finish, same error.
I just meant replace the rack engage motor. Not too expensive and likely the issue.
I see, any idea if this is a simple replacement or if I should call a tech? I am more than capable, but if it's 8 hours, I'd opt for a tech, if I can find one.
balstestrat
Problem Solver
It's pretty simple, maybe 10 minutes without removing the service station.
balstestrat
Problem Solver
That's good to hear, though I went and found a service manual and it is almost intentionally unhelpful. Any chance you have any info on replacing it?
It has really good instructions, step by step with pictures. Have another look.
JBurton
Signtologist
No the service manual that you got.
Man you're too patient, I appreciate the help. I think I found it, though it's frustratingly referred to as "printhead cleaning roll motor assembly". So the error calls it a rackengage motor, the part is a web wipe assembly, and the technical manual refers to it as a web wipe, until you look for the removal procedure, where it gets another name.
At any rate, does this look right?
JBurton
Signtologist
Forgot to say, the part came in, went in the printer easy, only found one missing screw on the cover, and everything works perfectly. Thanks bal!
Reactions: 1 users
cjohnson406
Hello sorry late to the party, but i'm having the same problem. i'm a tech and have replaced the motor and then the interconnect PCA. still the same issue. intermitent. Machine boots to ready. Then I try to replace a print head, it uses this motor several times during this process. It could throw the error on the first engagement or the 10th. do you or anyone else have another idea? The service manual only says those 2 parts. I have even changed the cableing for this motor.
