HP Flexi Sign & Print can't find Horizontal Weed Line option or easy weed
MACKAY
I have been trying to find the option for Horizontal / Vertical Weed lines in HP FLEXI SIGN & PRINT. When I check the help menu it shows the option in the CutPlot dialog Box Option Tab. But in my version the only option showing is Weed Border. Can anyone help? I have attached a screen shot of the dialog box.
FrankW
This functionality is available in cutting output only. Among other things because weeding lines could cut through printed areas.
karst41
Been using 31 years. It works? Yeah
I typically set a weed border only and avoid tight borders. Normal for
me is between 0.20" - 0.35" incremental by +- .05"
Depending on your Table Trimmer Spacing is . 25" 6mm is more accurate.
I recentl purchased a new MBM Triumph the Number is .269 on the spacing.
Heads Up.
Most trimmer tables are crap. an old Graphtec FC7000 - 130 is GOLD for a 55-60"
Trimmer table. Height is right and easy to retrofit the table top and a full roll of
laminated 3"x5" Labels
is Perfect for a heavy roll and that my dear friends make life much easier and that roll
is finished in no time. Yeas thats a whole carp load of labels.
I posted this here in this topic for a reason. Print this and save to your how to manual.
Cheers
