Sign Man Spokane
I'm using HP Flexi Print & Cut 12 Build [HASHTAG]#2898[/HASHTAG] with a HP Latex 315 printer as well for what that's worth.
So I'm having some pretty serious alignment issues when I go to cut some jobs. It doesn't seem to happen all the time but it's becoming more frequent.
On the first image you can see that plot lines are really far off. In the second image you can see how it's supposed to be cut. The really surprising thing is these were cut on the exact same job! Everything was aligning fine and then it started plotting way off track. Then it started plotting fine again. All off of the exact same barcode on the exact same job. The vinyl was tracking fine in the plotter the entire time.
In the third image you can see multiple attempts of me trying to plot this particular job. Those plots were supposed to be inside the diamond. One of those plots are from were I tried to scan the opposite side barcode.
Like I said before this is something that can occur mid plot. On some jobs, it will plot the left (if you're looking straight at the front of the plotter) side of the job fine and gets misaligned on the right side. It did this exact same thing on one of the first jobs I ever plotted on this thing almost a year and a half ago.
This has been a persistent problem but it has gotten much worse over the last week. I've wasted a considerable amount of my time and material trying to fix this. Any help you can offer will be greatly appreciated.
Thank you,
AJ
