I Built My Own Sign Software Using AI. So Should You.
Bobby H
Arial Sucks.
I've been using CorelDRAW and Adobe Illustrator alongside each other for over 30 years. Both may technically be the same kind of application, but each has a slew of unique features. So I take advantage of the best of what both have to offer.
We have multiple licenses of Flexi at my workplace, but I don't use it on my workstation. Flexi is useful in production, but it's pretty limited in terms of design capabilities. The UI feels like going back to the 1990's.
  • Agree
Reactions: 1 users
LizKeenan
Well thats where you and I differ. I have worked across several softwares, and TO ME the value in the designer is the versatility in being able to use different softwares. For everything Print I would use Illustrator. For sign design, I would use flexi. I understand your point. And it has value, but this whole industry is based around making things work for you. Illustrator is not a hard software to use. If you need to unround a corner you just manipulate anchor points. Illustrator will unround corners that are already told that it HAS been rounded prior from said anchor point. So it depends on the users level of skill IMO. Does that mean it could have better tools? 1000% but I don't see how AI has any bearing on that fact.
THERE ISNT ANYTHING that building an AI based production merchant/softwre does that any other software on the market already does. There are several to choose from. I just don't get the push. Its not helping anything. And until AI perfects the workflow for any particular business, its always going to have some drawbacks in its workflow and how the users interact with said software.
To me it just seems like nerds keep wanting to slowly infiltrate and take over blue/yellow collar industries.. and honestly Im not here for it.
None of what you are saying is wrong, but I still think there are tools to be made. You are right, the examples I have given can be solved with using other tools, Astute has been especially helpful. However there are some that haven't been whipped up yet for super annoying edge cases. For example the below illustrates a script to produce paneling with versaworks/ onyx logic to visualize panels and overlaps while still being able to nest and label. This was created specifically for odd cuts to be nested to waste less material than rip paneling, and since they aren't rectangles you cannot pdf panel them easily, nor would it include the custom cuts and overlap bleed. Plus we use CutMaster so this way we can add the marks we need instead of cutting it on our print and cut Roland with their marks. Is this useful? To us, very. At large? Onyx is still an excellent paneler that I am sure most people are utilizing that just fine.
Pauly
Printrade.com.au
I would love to see the code base of this app.
What stack is it running on?
Why did you choose the stack?
How did you deploy it?
Ive build many apps with AI.
I know what it can do when you have zero clue on how to code, and i know what i can do when you know what you're doing.
Its the same as print.
When you dont know "this looks good"
When you do "these reds are brown, missing nozzles, banding, blacks are green"
  • Agree
Reactions: 1 user
Think713
Anytime ive had to do overlaps like that I do them manually... I've never felt like I needed a script or ai to do that.
  • Agree
Reactions: 1 user
Pauly
Printrade.com.au
To make this more interesting, read in the voice of Morgan Freeman.
I've been in the sign industry for 20 years. For most of those years, I've watched us all complain about our software. Everybody knows the workflow can really SUCK! Everybody does it anyway because there's nothing better. Or they're using software that costs too much and still doesn't do half of what you need.
Screw... that.
I didn't want to waste my life on that kind of work. Why should I? I'm too pretty. I needed a better solution!
So I built one.
Actually, I built several. And they work on real world projects at 4x speed. That's not boasting. That's numbers.
Now here's the part that's going to make some of you skeptical. I built these with AI.
Before you close this thread...
I know. The AI conversation in this industry has been almost entirely about clients showing up with terrible ChatGPT logos and expecting us to print them on a monument sign. I get the frustration. But that's one tiny, annoying corner of what AI actually does.
Here's what nobody in the sign industry is talking about yet. AI can help you BUILD your solutions, custom fit. Not clip art. Not logos. Actual working software that solves actual problems in your shop.
I don't have a programming degree. I'm a sign industry professional. I could not have built these applications on my own. What I do have is domain expertise from years of soul-crushing, monotonous work. I know exactly what I want and exactly where the existing tools fall short. That knowledge is the hard part. That's the part AI can't do right now.
What AI can do is write code. And it's gotten scary good at it.
What it actually looks like
There's a lot of hype. Building software with AI is not "hey ChatGPT, make me an ADA app." That gets you nothing useful.
What it actually looks like is more like this. You sit down and you think hard about the problem. What does the workflow need to be? What are the inputs? What are the outputs? What are the edge cases? You sketch it out. You make decisions about how things should work based on your years of experience doing the actual work.
Then you describe what you need to AI, piece by piece. You test what it gives you. I make web apps so it gives me a webpage to review. It's wrong sometimes. It's wrong a lot, actually. But you catch the mistakes because you know the domain. You know that Braille translation has rules that most programmers have never heard of. You know that sign maps need to reference room numbers a certain way. You know what the production floor needs to see on a shop drawing. You know your problems.
The AI handles the code. You handle everything else. The design, the decisions, the testing, the iteration. It's a tool in your hands, not a magic button.
It takes patience and it takes critical thinking. You have to be willing to look at what AI gives you and say "no, that's wrong, here's why" and push it in the right direction. There are features I rebuilt over and over before they worked right. And there are still some bugs.
But the fact that someone from the sign industry can build production-grade tools like this at all? That's the point.
Five years ago, if I wanted to build a custom application that solves my custom problem, I would have needed to hire a development team (tens to hundreds of thousands of dollars). Developers who don't know the sign industry. I'd spend half the project just explaining what a message schedule is. That barrier is basically gone now. All that cost drops to the price of your AI subscription and your extra time. This is real right now. $100,000 to a $1000? Incredible. The software industry is collapsing... right... into... your lap.
Why this matters for you
Think about that for a second. Every one of you has deep knowledge about some part of this business. Maybe you've been doing vehicle wraps for 30 years and you know exactly how the estimating process should work but no software does it right. Maybe you run a shop and your job tracking workflow is held together with sticky notes and prayers. Maybe you've got an install crew and there's no good way to track field progress.
You know the problem better than any software company ever will. And now you have access to tools that can help you build the solution. Your solution. You don't need a computer science degree. You need to be good at thinking through problems, which... you already are. That's literally the job.
The real AI conversation
Most of the AI conversation has been noise. Bad logos, overpromising, hype. But there's a quieter thing happening underneath all that noise. Regular people in specialized industries are using AI to build tools that solve their own problems. Not billion dollar companies. People like me, building exactly what they need because they finally can.
That's the AI story worth paying attention to. Not the logos.
DO NOT SLEEP ON THIS.
Let me know if you want a tutorial. I'll write a post here to show you how to make something really simple to get your feet wet.
- i am 3toed, struck by lightning, bit by a cobra
still waiting for a response.
  • Agree
Reactions: 1 user
WildWestDesigns
Are we talking scripts here or are we talking C/C++ apps interfacing with Qt/IMGUI/raygui etc (for a full GUI experience etc) or I would even go TUI here, something like FTXUI?
I have found, outside of Rust (which not a fan of that babysitter of a language), "AI" fails at low low level programming (scripting, because even most devs now are just scripters/web devs only app devs due to the help of Electron and the like(even programs that most on here know use Webview even for their "native" app) and everything that is out there for "AI" to "learn" off of is really based on that aspect of programming, "AI" tends to do better with that). Having that "babysitter" of a compiler (Rust lang) helps with keeping it in check. Especially if one has to go back for many prompts for a particular session (it doesn't do well keeping track of what is what particularly on non trivial applications).
What I'm afraid of, just like with art/animation/coding people/users are going to be even more abstracted away from basic concepts (already happened with the takeoff of Python and Electron/webview, this is just the same thing on steroids).
I would argue that with kids using "AI" younger and younger in school now, they won't have the basics. Just like we have lost the basics with math, reading/writing ("AI" prompting will have to be abstracted away to just voice before one knows it), shoot even critical thinking (already have studies on it and already have places/countries trying to change course on it with going back to more analog methods in teaching). So this "know what you're doing" is going to be a very different beast pretty quick and probably be very lacking in what comes out in future products.
Think713
Aside the points mentioned about the coding softwares cause I know nothing about coding, i think your lower points here are where my heads going with all this AI stuff. I'm currently dealing with an operations manager and a boss and a designer all using AI tools, and its actually creating more problems for them. They're having to recreate solutions for things they already have solutions for in the name of "speeding" things up which doesn't really benefit anything.
Its the whole don't use a calculator unless you understand the equation first kinda thing. And its happening at a pace that I think basic intelligence is going to be lost incredibly quickly. Its scary.
  • Agree
Reactions: 1 user
WildWestDesigns
They aren't really totally unrelated. Most people don't really care, because they aren't artists/programmers etc. To them, it's the destination and not the journey (which in most of these endeavours, the journey is just as important if not moreso compared to just the destination).
This is orders of magnitude worse and we are actually seeing it now even with people that should know better, there are issues with this (the "AI Pause" is a real thing (this particular "pause" is about professionals "pausing" whatever they are doing to allow the "AI" to do it's thing, preventing any type of "flow state", to much stop/go). At least with the other concerns with letting tech run amok, it actually took a couple of generations, we aren't even getting through 1 generation with this before starting to see degradation.
pro-UP
I immediately wonder if we should train someone's ai to help overtake an industry that is pretty untouched as far as ai is concerned. The token usage for an ai agent or the resulting hallucinations will not out-value the lost work (more and more they are switching to token pricing instead of monthly subscriptions). I'm also curious what tech stack they are using.
Reading up on ai and watching people debate it's utility is a fun little time waster for me. I especially like Ed Zitron's take on a lot of it. They are taking a solution to solve problems that are already solved with other solutions. There is usefulness, but I'm not interested in sharing my "workflow" with something that has an over 30% leakage in security. These are all subsidized right now and prices will go up, more will close (like Sora), and soon only titans of industry will retain unfettered access (imo). The big guys are already making moves to cater more to the corp partners. They are finally addressing the security failings and that will make it much more interesting to corps. At this stage seeing how an ai program / agent erase a company's entire database in 9 minutes AND their backups is nuts.
rydods
Member for quite some time.
At this point, I plan to utilize AI in any beneficial ways I can building whatever apps that are helpful and implementing it in to make my business more efficient and I'm not telling a Damn person about it. Everyone can use AI for themselves. No one is going to create some ground breaking platform that works for every sign company and actually make any money from it.
  • Agree
Reactions: 1 user
Eforcer
Sign Up!
Screw... that.
So I built one.
Ai is DUMB!
Think713
What can AI do for you that is beneficial? For me I have used it to help me troubleshoot problems. But the things it asks me to do, or mentions pretends to be something close to the answer when really its just a ballpark. I've gotten better answers from experienced professionals that have industry knowledge here on this forum, than ChatGPT.
AI is only as beneficial as its training model. So how do you find it beneficial? And Im asking out of pure curiosity, not to debate.
WildWestDesigns
That's already happening and that was always going to be the case as it has been in tech even 30 yrs ago. There is a period of the "Wild West" after that consolidation to where there are only a few power players left for this type of usage. Now, there will be local "AI" usage that will probably be OSS, but the big boys will always will have this type of workflow.
I'm speculating here, but it was always catering to corpo partners. There the ones that benefit most from this (and why corporations are the ones that are really pushing their worker bees to be using it and their work evals dependent on it's usage. Data/telemetry is king nowadays. That's the new currency and has been for a very long time.
That has always been the case. Look at the programs that most on here use, Ai/Draw. They are not specialized software (I'm not talking about not specialized in say terms of vector creation, but within industry (comics, signs, game asset creation etc). They are generalized software. To get it in that specialized realm takes plugins to tweak things that are specialized. They are a base that people build off of. That is vastly different compared to some bespoke tool that is highly individualized, that in order for a software company to make, it would have to cost millions to make it and sell it to one customer.
I wrote a stop motion/2D animation tool (captures both DSLR and mobile/web cam pictures, has a dopesheet and exports various video/picture formats, small image editing capabilities), it's no Dragonframe (awesome software), but it has some features over on Dragonframe and it lacks some features, but it's all that I need, but there is no way that it will compete with Dragonframe as it's too bespoke to what I need and Dragonframe is more generalized and fits more people compared to what mine would. It's a non trivial app written in C. There is no way that I would attempt to do that using "AI". That would be a lot of back and forth prompting, "AI" ironically can't seem to keep track between so many prompts before it does something that breaks something else. Also "AI" doesn't tend to render the most readable code, which makes finding and fixing issues that much harder (and this happens with non trivial software even if one has written it from the ground up and comes back to it months later to fix or add something to it).
"AI" though is a cheat and I would argue not even as good of a cheat as power trace/live trace are as a cheat. It fools people that don't know where to look or not experts in what "AI" is being used for. Which strengthens the argument that those that know what they are doing can/will be able to product better results, unfortunately, that doesn't end up being the case as more and more people use it and don't really know what "AI" is abstracting.
  • Agree
Reactions: 1 users
EddieBS
IMO AI will get cheaper with time, maybe at the moment price will rise, but there are several developments on the performance of AI and energy reduction. For all human kind AI is here to stay and will be incorporated in our daily life/job. The ones who will find a way to use AI and/or automation to get their task quicker will gain advantages on the market. We found a way to fully automate illuminated sign quoting and 3D visualization. We put all this knowledge in a software so sign makers can have a competitive advantage. Is not perfect but is a starting point but work in progress.
WildWestDesigns
The thing that would offset that is typically when a market has fewer players in it, prices tend to go upwards, not downwards. Even if there is major breakthroughs in surrounding areas to offset costs, it tends to be negligible to what the end user sees, if at all. Not all savings that a vendor has is necessarily passed on to the customer. Especially if the field of vendors isn't that big.
I have no doubt that what passes for supposed "AI" is here to stay.
Both are a double edge sword. Some people try to shoehorn one/both into areas that doesn't really benefit. Automating everything for every situation doesn't always work out.
I'm more of a traditional luddite (most people think that it means anti-tech, it really doesn't mean that, but I digress). It's not that I don't like technology, I really like it. It's the implementation of said technology is where the concern comes in for me. It's being over done with regard to "AI", to it's own detriment. And at the level that it appears to be at (at least what a peon like myself is able to use) right now, it's results are quite lackluster.
Think713
This is where I am at with it. There are some things that AI simply doesn't understand the contextual use for. Automating EVERYTHING isnt a great answer because the training models aren't going to understand every use case scenerio for certain things.
You can automate a quoting process to be competetive but what is the point of that if you waste time building a sign after a client agrees to a price and you find out the town or city you want to put it has a clause in their permiting that doesn't allow for it.
There are so many things that this tech isnt accounting for.
EVERY design that comes through our doors that our designers have to use that was started with AI has to be manipulated or redone to be useful for printing. So what the hell is the point? THE ONLY THING it does (for now) that is beneficial IMO is ideation. Its a great starting point.
But this technology is already being subsidized at the expense of peoples livelihoods. This idea that we are going to support the long term growth that some how gets cheaper is a falacy. Large data centers draining resources that require updated technology in order for it to get cheaper isnt happening. And it isnt happening because transistors are as small as they've ever been. You cant pack anymore into chips and memory. We are basically at the pinnacle of physical technology has every been.
Which means either the tech and fossil fuel industry releases black project energy technology to support the increase of energy use OR they use the tech to create the needed bump. But do you really see that happening when Sam Altman locked up like 40% of the worlds RAM supply? I don't....
And every single day that we use this tech we are aiding in that fact. Whether we benefit or not. This technology currently is at a net negative to humanity.
WildWestDesigns
This, I'm not even sold on. It's a slippery slope. People start with using it for one thing, that spills into other areas to where pretty soon, one's whole pipeline is using it and if it goes down or one loses access to it (for whatever reason), those old creative juices aren't flowing like they once did. For those that never really had creative juices and were relying on abstractions to get further compared to if they had to rely on skill/talent alone, they are effectively dead in the water. It's not democratizing anything. Knowledge does that, not abstraction (which hides said knowledge).
People forget that in a lot of endeavours that they are trying to use "AI", the journey is just as important as the destination, if not more so.
Like with any high level abstraction (which includes automation), people need to learn first to know what is being abstracted and how to do it in case the abstraction is broken. Unfortunately, I know middle school students that are using "AI" instead of using their own minds. That's no bueno long term. As much as I love tech and see great potential in it, what ruins good ideas is implementation.
If I remember correctly, Jensen Huang said that we need 1000x more energy compared to what we have now.
Think713
SO if we need 1000x more energy, right now those energy costs are being offset to the consumer on grid. Therefor everytime we use the tech we are inadvertently costing ourselves more money in the long run. (UNTIL) the energy costs less. Which if you know anything about politics and business and corporate lobying, clearly thats not gonna happen OR there's going to be wars over energy. Which is probably why the WEF wants to commoditize everything, including air and water. WE are literally giving birth to a technology that is going to create the nexxus of our evolution as a species. We either get through this or we don't. And currently there are industry leaders in the tech saying they don't even understand how it works and there are ZERO safeguards in place to prevent it from getting out of control. So what do you think is going to happen to this and the rest of the industries that are using this moment to make a quick extra buck at the expense of our future? (thats a rhetorical question.)
But me personally I really don't like this "this stuff is here to stay, and we should embrace it" attitude. I'm sorry, I don't have any interest in training a fake robot to take my job so I can inadvertently make my life more expensive, and then have no income. Sounds like a really dumb idea to me.
