Really, it's all a question of time... Where is your time best served?
(oh, and I could probably use some exercise too...)
Now, you can sit at your work table, and weed out a vinyl
sign... Let's assume a little bit of detail... So, from the time the "cut" decision is made, let's say 5 minutes to load the color and cut, a minute to carry to the work table, and find the dang tools, turn the light on, etc., then 10-15 minutes to weed it out. Then you slap some app tape on it, position some coro, and peel and place. So you've got 15-30 minutes in one
sign. We'll call it $50.
Fun part is, #2 will take about the same time. So will #3. And #4...
With digital, I hit "print," and do something else. When the printer finishes its thing, it's a few minutes to trim them up (let's say 2 minutes per sheet). Then it's time to put down several pieces of coro to hold the individual chunks... I lay the first slab in, tape the trimmed sheet down, roll it, peel the back a little, and squeegee. Pick it up, carry to the other end of the table, put it face down, and x-acto the edges to remove the margin vinyl. Then it's back to the first end of the table... Upside is that, print-time not included, I can probably mount 20-30 faces/hour. Maybe more.
Now, assuming that you can weed and mount 4 cut vinyl
signs/hour, that's $200ish, assuming you can get $50 each.
If I'm doing 20 digital coros at $18 each, I'm at about $360ish.
You know something? I'll take that! I'm not trying to have one client buy me a Mercedes either...
