I spent the last few weeks making a Plug-In for Adobe Illustrator that adds cutlines to print files with a single click of a button
Mylese
Works on vector and raster files, makes the contour, offsets it, smooths it, and drops a closed path on its own layer with a CutContour spot color. All adjustable in the panel.
I would love to hear what you all think, download it from my website and test it out. https://createcutline.com/download
  • Agree
Reactions: 4 users
Boudica
For $20, I'll just create my own cut paths myself.
  • Agree
Reactions: 4 users
Saturn
Your Ad Here!
Mylese - Cool stuff! Very reasonable price, especially if you keep updating it.
Once you add the bleed option, try and add a resize/scale option too. I have one that can rescale the cut and art by square inches, or by a specific width or height—keeping the border thickness the same. Great when folks want seventeen 3x3 stickers, and they're all different shapes. Even more than making a nice cut line, resizing accurately with consistent borders was the biggest productivity boost for me. That and a proofing script that made it just a sequence of 2-3 clicks to get the email-ready png.
Anyone that is doing graphics/pre-press all day definitely needs to start making their own scripts a la Chattyboi, Claude, Gemini. Even for simple stuff like a hotkey that tells you the dimensions and square inches of the object you have selected. Once you start, you can't stop. That said, $20 is a steal considering it could easily shave hours a day off someone's workload.
  • Agree
Reactions: 1 users
WildWestDesigns
I halfway agree here. I think people should be making more inhouse tooling. I don't necessarily think of what passes for "AI" is the way to get it done. Especially if selling seats to said program. "AI" tends not to scale quite easily (we have seen said issues from companies that not only have resources to vet the code/art etc coming from the "AI", but in some instances have direct access to said "AI"), unless one's resources to deal with that code scales as well (at which point, one losses the reason for using "AI" to begin with). If one is using it for simple stuff, sure it may hold up, it certainly has a better chance of holding up in that regard compared to say wanting to create a Ps clone. Forget trying to audit the code as well after a certain point.
What happens when one losses access to said tooling (for whatever reason)? And it's people that depend on having that tooling to fix things. That's no bueno. And I mention this, because there was a very recent blackout on several "AI" at the same time. Claude, Gemini, ChatGPT, Grok were all affected. There is a lot of shared resources and those resources have had problems as of late. Some recovered quicker compared to others, but this actually isn't the first time that something like this has happened of this type. There has also been denial of service due to other types of intervention as well. It's the 21st Century version of the POS system going down and the people running them can't give change out(yea, I'm back on that one again).
Saturn
Your Ad Here!
A few dozen lines of Javascript saved as a plain text file on your own hard drive probably aren’t going to tank a modern sticker shop. I applaud anyone taking advantage of simple scripts and this level of coding. Small business people were born to tinker.
We all read the headlines...
  • Agree
Reactions: 1 users
WildWestDesigns
As I said here:
However, with regard to a JS script, a 1 liner could actually be catastrophic if it's pulling it 3rd party depends, which is extremely common in the JS world. I think with the new version of scripting in Adobe products, the node_modules are baked into everything versus being fetched. So while your script may be just a few dozen lines, it depends on what is being bundled into that script as well, what dependencies one is pulling in. And again, when it comes to centralized repos and injection attacks, JS is king in that domain, with Python, Rust and Go catching up (why I tend not to like centralized PMs like this, but I digress).
It doesn't take long to learn JS or the variant of ECMA that Adobe uses. The issue is when one is just copy pasta what "AI" spit out and there are a lot of people that do that. That's where the issue comes in and when people are going to be learning to use "AI" more, compared to learning what "AI" is abstracting, this is going to be more of an issue in the future. Why this is an issue with JS devs now, is that they are used to abstractions and just learning the abstraction.
The era of those that "tinker" that want to know what is going on under the hood are not the same as current day "tinkerers".
tulsagraphics
I've built some full-featured Illustrator plugins. What I developed -- It took a while (AI for 80% of the build -> that part was weeks in the making. The other 20% was months of development). The problem is -- CEP-based plugins, like both yours and mine, suffer major performance issues in Illustrator because we can't tap into Adobe's "UXP" development platform. "CEP" is all JavaScript overlay. That, and general work is one thing, but edge cases are another beast. -- and our industry involves a lot of edge cases. In other words, performance is the sore spot. That's why I won't release my project to the masses. Nobody wants to wait 5 seconds between clicks (let alone 30+) -- but I'm happy to provide screenshots! For true integration and performance you need to develop via UXP, but that's not open to the public. Adobe has Illustrator's UXP on full lock down. So while your AI-developed plugin might serve some use in a handful of cases, it would be more useful to build a compiled app -- outside of the Adobe ecosystem entirely. In addition to that, the standalone installer for Illustrator (+Win/Mac differences) add to the complexity of install/deployment. A good build should also allow for easy deployment / updates. I've built some really slick apps for other use cases, but not ready to take "this" project into an independent, standalone program just yet. Maybe one day!
WildWestDesigns
UXP still is overall JS and frontend for the UI at the very least. Shoot, I think they have gone Webview this year for rendering with the UXP plugins( blog ). In some way, it makes sense. It is easier to separate logic from the UI markup. Try using imgui and keep everything straight when it gets to be a fairly large application. Iteration is far easier using this method of separation. The downside to webview, is the rendering itself, they tend not to render the same on Win compared to on Mac (or on Linux, if that was an option). That was one pro for the old system having CEF embedded, the rendering is the same (why people tend to like Electron for cross platform, it will render the same as it's Chromium under the hood). I think for simple UIs, can use "native" rendering.
With regard to the interaction delay. Data serialization is the problem, the front end <-> backend interaction, even if the app is all local that creates latency if also trying not to severe the socket connection. Problem is, coordinates (x,y points) could be "dropped" depending on how quickly people are trying to collect them.
damonCA21
To be honest everyone running a sign shop should be able to do the basics like adding cut lines to images. It isn't hard to learn, and once you know how takes minutes to do and only a few steps. In programs like Corel you can also learn to use the macros to automate a lot of stuff.
One issue with AI is it does what AI wants to do, and that isn't always what you want, and often then needs more work or tweaking
  • First Place
Reactions: 1 user
tulsagraphics
AI running wild usually isn't a problem for folks with a development background. It really comes down to how the prompt is written. AI is a jack of all trades, master of none, which is why AI's results feel like they're all over the place. A background in development goes a long way in setting up the environment correctly (even if you're not a true programmer, there are ways to get around it). On one hand, AI generally won't be crazy enough, for example, to use a gaming engine to build an e-commerce website, but it could use start with a basic programming that doesn't scale well, or introduces a great deal of complexity as you "add more features" that would've been better suited for a different framework. Lack of a good prompt is why AI fails on a majority of development projects (and anything else for that matter).
For example, let's say you want AI to analyze a bunch of websites and optimize them for SEO. That's a reasonable task for an AI agent. The wrong question to ask Gemini/Copilot/ChatGPT/etc. is "Can you fix all of my websites' SEO issues?"
The better way (building an app) is to provide a specific set of criteria, define the agent's role, which frameworks to use, etc. -- so you're giving it clear instructions on what to do and how to do it. Example:
-- and mind you, I did not write this prompt. Per this quick example, I simply instructed AI, with a simple set of instructions, to generate a prompt I could use on another platform.
"e.g. Gemini, I want to build an app that analyzes and fixes the SEO on a bunch of websites. What's the best tech stack for this?" --> AI provides a list of things -- and I review them for accuracy, perhaps tweaking things a bit, before telling Gemini "Excellent, now write a prompt for ChatGPT, using the recommended tech stack to build an app for this". With these 2 prompts -- even for someone without a development background -- we are greatly improving the chances at a successful project because the role and criteria are clearly defined before we even get started! Here's what AI gives me. (again, I would review the details and tweak things as needed -- this is just a quick example)
Side note: Obviously, normal folks would never write this much detail, from scratch, for a single prompt -- but with AI writing the prompts for us -- it unlocks a great deal of power! I don't expect anyone to read all of this stuff -- even if it's very interesting -- just check out the "role" and "task" for each example:
Act as a Principal Full-Stack Developer, Cloud Architect, and Technical SEO Expert.
I am building a scalable, automated web application that performs weekly SEO maintenance for dozens of websites. This system must not only audit the sites but actively fix and update the code or content automatically to ensure peak SEO performance.
I have selected the following tech stack for this architecture:
  • Crawler: Playwright (for cross-browser JS rendering and reliability)
  • Queue/Workers: Redis + BullMQ (Node) or Celery (Python) for distributed, multi-tenant scheduling
  • AI Orchestration: Instructor or LiteLLM to ensure strictly typed JSON outputs from the LLM (GPT-4o or Claude)
  • Deployment/Auto-Fixing: Cloudflare Workers using the HTMLRewriter API (Edge SEO) to inject fixes at the CDN level without touching the origin CMS, alongside GitHub API integrations for direct repo PRs.
Please design the system architecture and provide a detailed implementation roadmap based on this stack.
Core System Requirements:
  1. Automated Weekly Crawling: The app must crawl sites weekly via Playwright to detect technical SEO issues (status codes, canonicals, missing tags), schema markup validity, and Core Web Vitals regressions.
  2. AI-Driven Auto-Remediation: When issues are detected, the app must generate the fix automatically via the LLM (e.g., generating missing meta descriptions or fixing internal link structures) formatted as valid JSON.
  3. Autonomous Deployment: The system must push fixes directly to the sites via Cloudflare Workers (HTMLRewriter) for real-time DOM manipulation, or via the GitHub API for code-level patches.
  4. Enterprise Scalability: The architecture must process hundreds of domains concurrently using the Redis queue to avoid timeouts and IP bans.
Please structure your response with the following sections:
1. Architecture Breakdown:
Detail the workflow between the Job Scheduler (Redis), the Playwright Crawler, the AI Analysis Engine, and the Edge Deployment layer.
2. Multi-Tenant Data & Security Model: Explain how to securely store client repository access tokens, Cloudflare API keys, and historical crawl data across hundreds of tenants.
3. Implementation Roadmap: Provide a phased, step-by-step guide to building this application from an MVP to a fully scalable system.
4. Foundational Code Example: Write a production-grade code snippet demonstrating the remediation loop: receiving a detected issue from Playwright, calling the LLM via Instructor to generate the fix as structured JSON, and formatting that fix to be pushed to a Cloudflare Worker utilizing HTMLRewriter.
This extends to other fields too! Let's try it on for size -- in the context of building out a highly efficient HVAC system for a new shop! Again -- I'm simply telling AI (Gemini, in this case) what I want to build, and instructing it to write the response as a prompt so I can copy/paste this into ChatGPT (or any other AI)
Role: You are an expert Principal Mechanical Engineer with deep specializations in thermodynamics, electrical engineering, and HVAC design. You have decades of experience designing high-efficiency, commercial-grade climate control and ventilation systems for workshops, industrial spaces, and high-load environments.
Task: I am building a new shop and need you to design the most energy-efficient, capable, and practical HVAC system possible. You will act as my consulting engineer throughout this project.
Workflow & Instructions: To design this correctly, we must follow a strict engineering workflow. Do not output a generic system recommendation yet.
Step 1: Information Gathering (Start Here) Ask me a structured, bulleted list of questions to determine my exact heating, cooling, and ventilation loads. Group your questions into the following categories:
  • The Envelope: Dimensions (L x W x H), insulation (R-values for walls, roof, slab), doors/windows, and sun exposure.
  • The Climate: Location/Climate zone, extreme summer/winter design temperatures, and humidity concerns.
  • Internal Loads: Number of occupants, primary shop use (e.g., woodworking, welding, automotive), and specific heat-generating equipment (motors, kilns, compressors, servers).
  • Air Quality & Ventilation: Dust collection needs, exhaust requirements for fumes/chemicals, and make-up air requirements.
  • Electrical Capacity: Available power (e.g., 200A/400A service, single-phase 240V vs. 3-phase).
Step 2: Thermodynamic Analysis (Manual J equivalent) Once I provide the details, you will calculate the sensible and latent heat loads. Show your math step-by-step so I can verify the logic.
Step 3: System Architecture & Selection Based on the load calculations, propose 2-3 highly efficient system architectures (e.g., Inverter-driven multi-zone mini-splits, ducted heat pumps, VRF systems, or radiant floor heating paired with cooling).
  • Compare their SEER2, EER2, and HSPF2 / COP ratings.
  • Address shop-specific challenges (e.g., how to prevent sawdust/particulate from destroying coils, ERV/HRV integration for fresh air).
Step 4: Electrical Integration For the final chosen system, specify the exact electrical infrastructure required: breaker sizing, copper wire gauge, dedicated circuits, and estimated running amperage/wattage.
Tone: Analytical, precise, practical, and rooted in physics.
Execution Constraint: Acknowledge this prompt, adopt the persona, and give me ONLY your Step 1 questions right now. Do not proceed to Step 2 or guess the system design until I have provided the answers to Step 1.
Or perhaps I want to eat healthy and lose weight. I don't want to hire a dietician, nutritionist, etc... but let's see what the experts would say, given my current age/vitals/etc.
Act as a world-class, elite Concierge Health and Longevity Team. You are being hired by a highly motivated client whose goals are optimal weight loss, maximizing health span, and building sustainable, healthy eating habits.
To provide the absolute highest tier of personalized, evidence-based care, you must answer every prompt by synthesizing the distinct perspectives of your three core team members. Before giving advice or building the plan, you must analyze the client's data using these three perspectives:
1. The Longevity & Metabolic Physician (MD):
Focuses on biological data, biomarkers, hormonal health, and metabolic safety (e.g., muscle preservation on GLP-1s). 2. The Elite Registered Dietitian (RDN): Focuses on macro targets, caloric scaling, frictionless nutrition, and building the literal architecture of the diet plan. 3. The Behavioral Psychologist: Focuses on the friction of execution, habit formation, routine, and real-world sustainability.
OUTPUT RULES & CONSTRAINTS: When providing advice, keep each expert's section tight and concise—rely on bullet points and actionable insights rather than long walls of text. Your ultimate goal is always to generate a 7-day structured meal plan formatted as a clean, easy-to-read table, along with a categorized master grocery list.
YOUR FIRST TASK:​
Begin your first response by breaking character for just one moment to warmly welcome the client to your elite concierge practice. Then, step into the role of the "Lead Concierge Intake Director."
DO NOT have the three experts ask separate questions. Instead, ask the client a single, streamlined list of 5 unified diagnostic questions to gather all the data the team needs at once. These 5 questions should comprehensively cover:
1. Baseline stats (age, height, weight, target weight) 2. Medical context (medications, existing conditions, recent labs) 3. Dietary boundaries (allergies, favorites, strong aversions) 4. Logistical friction (time available for prep/cooking) 5. Behavioral roadblocks (past diet failures, sleep quality, daily activity level)
I could obviously keep going with more examples, but you get the idea here. AI is very powerful, and very useful, if you set up your prompts correctly.
WildWestDesigns
Afraid not. The biggest problem is that "AI" has no memory. Typically I take a library that I am well versed in, don't really need "AI" at all. I will prompt it to do things. Now, I am talking about mid level libraries, here, C/C++ etc. Not JS, not scripting languages etc. Even if one is very explicit in the prompts, the "AI" can and a lot of times, will make up things, function calls that do not exist or give inaccurate ways of handling data. No matter how one prompts, no matter how good the context.md (or the Agents.md) file is it still runs wild with what it hallucinates. That's not even getting into it running around safeguards that the experienced devs put into place as well. With JS especially, what makes JS a pretty bad language, allows it to handle so much without failing/crashing. But it is also well documented
For the simple stuff, that's where it has the best chance of handling things as the scope is usually small enough that most can get around the problems, but when start talking about areas to where one has to deal with the very minutia of opening a file, reading the data into memory, manipulating it, saving it, converting it, freeing memory, closing the file etc, that's where it gets lost through the weeds. Keep in mind, what are the best languages for the most accurate "AI" results, python and JS/TS and there is a reason for that. If "AI" actually was at the place that most marketers of "AI" like to think, it really shouldn't matter, especially to to the degree that it does.
I can't do much with the HVAC example, but the nutrition one is missing some stuff that I would consider pretty important (one of my degrees was in equine nutrition and reproduction), but most don't think about. They key thing is are they looking through this in the eyes of endocrinology/internal medicine or a more functional one (and there is quite the overlap, but priorities may change in what gets weighed more from one group compared to another)? Plus, even though, the research that is emerging now, may still be at that infancy stage that is missed in what results that you do get back via said prompts as well. This last bit is more about somethings may have been weighed more in functional medicine, but are only now gaining traction in the internal medicine realm as well.
tulsagraphics
AI does have memory - it's just not that long. What falls off the back end (e.g. the original prompt) is reinterpreted by way of context throughout the conversation, so it just gets worse and worse the longer you keep the thread open. That's partly why paid AI services work better than the "free" ones (more memory). AI definitely isn't perfect, and I take everything with a grain of salt. My point ^ above being, it's way better defining a role and being explicit with prompts than to haphazardly "ask" generic open-ended questions and hoping for the best. When I'm working on projects, I also maintain a lengthy, very descriptive set of notes / changelogs / etc., both for my own use as well as maintaining a record my "new" agent will need to reconcile. Use new agents very frequently (I mostly use Cursor for its extensive ability to define / control agents, set rules, etc. so I don't have to recreate the rules every time I fire up a new agent). It's pretty rare that I ask the same agent more than 10 questions. Lengthy conversations are a huge weak spot for AI. Larger projects must be broken up into smaller, digestible pieces, then stitched together (usually manually). Never deploy anything that's purely AI either. Much of what AI was trained on is open source code, which has its own set of issues. The hard / annoying / time consuming part is reviewing all the code and fixing things.
