I thought it was time for a redo.......
Pro Image
I have been playing with this on and off for a while......Any suggestion will be gladly taken........Even the ones that I know are going to come.....:rolleyes:
The font for the wording at the bottom is up in the air also.......
The color are not set where they are at but I would like to use the colors that I have.....Silvers, Oranges, Yellows, Black, and White.......
Thanks.............
S
SignTech
Guest
I like it Dustin. Are you interested in the word "Image" In all white as opposed to gradient gray with a touch heavier black outline?
Anyway ..... looks nice.
D2S
I like it but I might lose the text on the bottom right or make it more legible
Flame
Came up with a quicky idea. My suggestion, keep the tagline away from your logo, and only add the phone number when needed (for example, on mine there's a line to the left. You can put a phone number there if you want, or if you don't want to, the line still fills the space).
Just something to help stir the thinking pot...
Pro Image
I got rid of the wording and Im playing around with the phone # a little........
Thanks.......Keep them coming.......
D2S
When I look at that not sure i Feel the gradient, does flow much better without the wording though so that is a plus
MasonJars
I am liking the title somewhat italicized but make the phone number more upright with dots instead of triangles - just a thought from the peanut gallery...
Marlene
the phone number has too many special effects. I like the triangle bullets but the box is a little too much. It looks pretty good other than that.
D
DARLAK
Guest
ditch your current idea and start playing with flame's..
try not to put so many effects on it, try and make the phone number legiable
striper14
Like the main Pro image. maybe make the centre of the O an eye or tv screen or something. Hate the phone no. , too busy and the small text is unreadable. My view is put all the design in the main name and keep the other stuff clean and simple. Sounds easy !!
Murmanation
I've gone back and forth with the multiple stroke colors around copy recently, mainly because I played with it on a logo recently.
I would be more apt to do one stroke with some sort of bevel or drop shadow, but for some reason your version works a great deal.
And as you and others have said, less words is more. Taglines, phone numbers and addresses should be reserved for special circumstances. Then again, I'm a hypocrite because my tagline is in with the logo for my freelance business. I justify it mainly because I have a one word name :). But what do I know.
