If you could make this... How Much
Derf
Surface painted screen printed text!
I tried to get out of screen-printing but they will not go for it.
They only need 2 to 3 about every few months (tenant change out)
So how much should I charge? I have a figure in my head but I have not pulled the trigger yet.
:thankyou: :U Rock: :thumb:
Flame
$25 screen setup charge and then $10 to lay on the print. If that's all you have to do, then I guess $35 each. I dunno, I don' really screenprint too much, does anyone else agree or disagree with me?
Rick
I callout a lot of screen printed office signs, usuallt sub-surface though.
This is a toughie because you can stock prepainted blanks to start, it makes no sense to spray one at a time. Off the top of my head you have to at least stock the paint color and ink, a few blanks and screens as needed. 2-3 every few months is not that much so I'm thinking 200-225 each if they order only one. If you are doing 2-3 at a time then discount 25-30%. Sounds high but there is not a lot of money in sign maintenance untill they redo the system.
Derf
this is where people get in trouble with pricing!
Here is what needs to be done as far as work.
1) drive to job site to survey and get sample
2) provide proposal
3) Provide Art for approval
4) get paint matched
5) Pick up paint
6) cut plex
7) Paint plex
8) Production art
9) screen set up
10 Mix & match off white ink
11) print
12) Add tape on back
13) Wrap up sign
and this is if you have most of the supplys on hand.
$35 is a bit low even if I just printed it...I have a shop rate of $75hr
Derf
Thanks Rick!
Your thinking the same way I am at this point!
I'm making 10 suite sign blanks and 10 directory blanks to have on hand.
Rick
I worked at a few companies that did sign maintenence, those film inserts were 75 bucks a pop for a single tenant...the price went down considerably when they did multiples. Your going to lose money on that first order but if they keep coming back on a regular basis, the next sign will only take an hour from phone call to shipping. I don't do maintenence accounts myself, but some places will charge a set up fee for the complete system that way it's not so painfull to start a new account. You might think about a set up charge for the first sign to take the sting out of surveys and approvals on the first round.
Derf
They are my #1 customer and the just picked up ten buildings. I charge them $145 for the same size sign sub surface applied text backsprayd black.
I'm thinking like $245ea and they want 4 now plus a bunch of vinyl work out side to change the management company signage.
I just need to check and see if I need to bump it up once and a while.
These are going to suck to make cuz I'm not set up for screen printing... I'm getting set up quick (trying any way!)
Flame
Okay Derf, I thought THEY were providing the sign material! I thought it was already installed and everything, you just had to screen it.
Totally scratch what I said. Of course you should add in a drive fee and for any artwork, I guess I was just talking about screening some names on.
Forget my post, forget I was even here.......
Derf
No thats cool flame! I knew thats what you thought so I posted up the work list.
Thanks for the reply however.
iSign
I do a couple buildings for tenant name changes. I've been charging $90 to clean an old name off avonite & print a new one in it's place. Another $90 to remove & replace... & $50 per trip on orders under 3 signs.
New plaques are around $250 (beveled & polished avonite)
One day I was in a hurry & cut stencil mask... sprayed with Krylon H2O... you could hardly tell the difference!
I would offer to do the signs at slightly reduced prices from what you mentiond provided they buy a one or two dozen minumum of blanks & paint them all at once. $125 ea. for the blanks in one dozen increments... $120 for screening new tenant names.
mtmdesigns
what u can do instead of screening is, get .25 matte finish plex apply the vinyl on the reverse side and paint. then apply a flood of black vinyl on back.. I think that's the Way it is done in your pic, because screening on matte finish plex scratches more then normal. Almost positive. And that is .25 matte finish plex.
Derf
I do that all the time however in this case I MUST match what is there. One reason is because the directory is surface painted and screen-printed so if I stick a sub surface applied, back sprayed sign in the mix it will look like ass.
And yes this sign is scratched and will scratch easily as will the new ones I will make. so will handle them with care and if the tenant scratches them they will need to buy a new one :Big Laugh
