ij180v3 bubbles
WOODBS
I noticed a couple of small bubbles in ij180v3, they wouldnt push out as in Oracal products...had to pinhole? Any one else have this happen?
modernmav
i'd say probably 95-98% of the time they push out for us. We usually just tap on them with our fingers and they come out fine. Only if its really bad air pockets that are completely sealed will they not come all the way out.
SSG_SIGNS
We usually have that problem when they form over an area that I have primed but other than that they pretty much push out.
MikePro
i don't mind pin-holing bubbles, just give it some extra heat once you go to push it down... to reactivate the adhesive, since it was most likely sitting there for a bit before you got around to fixing.
