I'll Risk It.
Geary
Thank you kind sir. :wink: What are you doing up so late .....enjoying this nice San Joaquin evening? Letterman's on....gotta run! :tongue:
~Gear
RedlineMan
OK;
Some liked the car, so I kept it even though it creates balance issues to my eye. Some said too busy. I like the wheel detail, but thought it was potentially distracting, so I eliminated it. Also helps with Trademark issues, I'd wager. Someone said use a script font for Redline. I did that (I thought). I even came up with something completely different, which I think borders on generic.
I'm dense I guess.
:thankyou:
Gear - Thanks for your continuing support, but I see that as utterly generic. Everybody uses that slash type script for something they want to seem edgy and bold and dangerous. I resist things that everyone else does, by nature. Just my opinion of it... not you. :thumb:
Geary
HA! That is interesting RedlineMan. :tongue: I was doing exactly what you were suggesting about getting away from "generic" images. Because your examples not only reminded me of generic from like the last 4 decades ...the fonts used are old fashion and kinda ummm well not attractive.
As a point of correction, that's not a "script" that is used on the first line in your example. That's just a plain ol' sho-card single stroke. Again, something that's been around for about 50 years.
I think you are right.....it's just a difference of opinions and image preferences from a west-coaster to back in your neck o' the woods. :thumb: That's ok man...like you said ...you "took a risk" These are all just opinions. :wink:
Later days!
~gear
RedlineMan
HA indeed!
Interestingly, that font was gained from a font site under the categoary heading of "scripts." Perhaps this begs the question, "what is a script?"
SBowlerDesign
Redlineman-
Here is more what I had in mind. Obviously, it needs work, too, but wanted to give you a better idea of using a script for Redline, and also incorporating a red line in the design. Still not crazy about the car silohuette, maybe you could look around for a sleeker interpretation of the car. Keep working on it, you will get there!
SBowlerDesign
Oops, forgot to write that there are some variations of typestyles at the bottom. The two scripts I used are Signfonts Snapper (in main design) and Signfonts Signwriter (alternate type). The other font is Univers Narrow Bold
and Univers Bold Extended. I do not know if you have any of the scripts from Signfont, but you should definitely check these out!
Jillbeans
SBowler, I like that...I think the red line idea is clever.
I like your scripts, and Gear's as well.
Your version looks very clean.
Any of those were more along the "line" of what I was thinking.
Altho using caps and lower case in Redline, as Redline did, helped too.
I'm not keen on your use of a calligraphy-type font with the casual on your newer bottom version. (#15)
Adding a reverse panel, as SBowler did, helps to ground the design.
Love....Jill
Geary
Script 101
HA indeed!
Strictly speaking a "Script" is a style that incorporates broad flowing upper case elements together with lower case 'usually' being connected and using longer ascending and descending strokes on characters such as "k, l, y, and so on..." Oh, and script typically italicised.
Scripts are fun to play with if you are proficient in calligraphy (brush or pen) and using a digital tablet is a blast.
Have fun!
RedlineMan
Funny;
Because they are the same font. Oh... I must confess I cheated and doubled the font in "Redline" (copy/paste/move right/weld) because it was not strong enough, but...
Bowler - I really like those fonts, but I'm not sure I want that look. To those who thought mine were cartoonish, well... yes. It was somewhat intentional. I'm not saying they work, but I was looking for something different. Slick is slcik, and that's fine, but then there's memorable and distinctive.
I do appreciate everyone chimning in. FWIW, I was not sold on my stuff either. That's why I posted! I'll keep fiddling.
Craig Sjoquist
just for my 2cents worth liked the one with lowercase used on redline with a larger bottom copy in caps tho very hard to read on this one, the others you could .. likes the red white and blue colors very american, most racers are proud to be american
freedom is not free
Geary
I happen to like some "cartoonish" but, it depends on one of the many styles of "cartoon" that can be. For instance, if you'd employ the services of say our own Mr. John Deaton for his VERY distinctive cars he hand draws.....THEN you'd have something brother! :thumb:
As a suggestion: http://www.deatondesigns.com/vehicles.html
RedlineMan
Yeh...
I thought folks might like that bottom one a bit. I do too. Obviously I tried to "integrate" the R a bit by playing with the shadow. Now that you mention it, it is still a bit remote. Let's tweak a bit.
The top one is the previous. The middle is with the "edline" moved. The extra black space this created under that section of text bothered my eye as much as that between the R & e previously. I added a red line to fill that space just for kicks, and the blue test of course.
Thoughts?
