Illustrator 2020
I do graphics and page setups for printing. I need my programs to be familiar and dependable. I want to do my work. I am not a gamer looking for new thrills. So if a certain bunch of software is doing what I need, then I see no advantage in upgrading to more expensive and unfamiliar software. Your customer, who is most likely not a printer, is not going to have the latest Corel or Illustrator to send you their files that they have been working on. Not happening. Most likely he is going to send you some crap he made in Canva. And you are going to take the idea and reset it from scratch in a real program. So your own ease in getting your work done is the most important thing, Not the latest bells and whistles. Those new features may be nice. but it's rarely something you can't already do in your own way.
WildWestDesigns
What would be so different about newer versions of Adobe Illustrator versus the CS6 version? The basics of the user interface are pretty similar.
If I'm not mistaken, they have gone to more context aware panels/menus depending on what one is doing versus having dedicated panels/menus. That can be a point of concern. I think that can be changed, but again, that's something that has to be changed on the user side (remember "power of defaults"). The one thing that I would have liked from this newer version is being able to create my own "toolbox", I think is what they call it.
Maybe there are some 3rd party plugins that they guy likes that never made it over to newer versions (or they themselves have deprecated functionality)
Any 3rd party licensed part within the program is up for grabs for not being there anymore. Any of those 3rd party fonts that need internet connectivity could be removed at a moment's notice (they may or may not give notice, their EULA gives them that ability, even though they may give notice, in their EULA, they can do it a drop of a hat). Spot Colors for Pantone is another casualty. Premier has the Dolby issue if I'm not mistaken as well. Not Ai, but just shows what could happen relatively quickly.
Now, those are my reasons, not the one's that netsol's worker may have, but not everything that is new and glitters is gold.
I would either go legacy if have to for whatever reason and just virtualize it on a well resourced computer (do not emulate, there is a key differences between those two) or go to a different vendor. While going to different commercial vendor is going to be hard without the same cloud issues ("AI" is another, but I'll leave that alone for now or try to anyway), there are still some out there.
Bobby H
Arial Sucks.
The artwork I get from clients runs the gamut from being professional-level stuff on one end to purely useless garbage on the other.
It's common for me to get Adobe-flavored artwork from larger corporate clients. Those files are often saved in the latest versions. That's because it's faster/easier for someone to hit the "save" button or Ctrl+S than save the file down to earlier version compatibility. So I need the current versions of apps like Illustrator for that stuff.
The smaller time clients are indeed more likely to use less professional apps like Canva. I have at least a somewhat better chance being able to salvage "PDF for Print" artwork exported from Canva by opening the file in the latest version of Illustrator and using the Vector First Aid plugin on it than I would trying to import the crap into an ancient version of Illustrator.
The thing growing into a worsening headache lately is all this AI-slop bullshit getting submitted by clients now.
Anyway, a number of the newer features added into Illustrator in recent years are pretty useful to me. Some of them are actually geared toward sign design, like being able to size text objects according to their cap letter height and being able to align text objects according to glyph bounds rather than that damned Em box. They still need to add align via baseline functions. But object snapping via Smart Guides isn't too bad an alternative.
You can set up the workspace in Adobe Illustrator however you want it. A new install will default to a more minimalist UI. I go to Window>Workspace and change it to the Essentials Classic workspace. That gives you what looks more like the classic 1990's Illustrator UI. Illustrator has several other stock workspaces. Workspaces can be customized and saved.
WildWestDesigns
The irony is I have gotten professional stuff and it still ends up being bunk and that is regardless of what program one is using (really it's knowledge that separates the two here (or how open ended your definition of "professional" is) for final production.
Power of defaults strikes again.
Ironically most are chomping at the bit for that stuff, Adobe included. Which actually makes things worse for me when I have to deal with NDA type of stuff.
That does not change the contextual panes/menus that I am talking about. That would have to be changed with a little more involvement. What you are talking about has been around for a very long time. At least the skeleton of that.
Bobby H
Arial Sucks.
I get a lot farther along opening something like an Adobe Illustrator .AI file in the native Adobe environment than trying to bring it into CorelDRAW or Affinity Designer where the artwork is more likely to break.
Opening a person's Illustrator file in Illustrator can indeed still have problems.
People are lazy as hell about converting type objects to outlines when sending art files to others. I'm not always going to have the same exact fonts they used in their file. But if they saved the .AI file with the normal settings I can place/link a copy of the file and then use the Flatten Transparency dialog box trick to convert any embedded font data to raw outlines. I can then work the outlined lettering objects into the native .AI artwork and be good to go.
Some people are really bad about going nuts with transparency effects and blending modes related to transparency (such as Multiply, Screen, Overlay, etc.). It's okay if they do that work in CMYK. Unfortunately some people do that work in RGB because the colors look more pretty. If artwork with complex transparency effects is moved from a RGB document into a CMYK document the colors are going to shift very noticeably. That forces us to keep the artwork in RGB all the way to the RIP and then cross our fingers and hope it prints okay.
The only thing I see changing in my Illustrator workspace, based on what is selected at the time, are the features in the Control Panel bar across the top under the Application Bar. Some users will allow panels, such as the Properties Panel, to be opened persistently and hogging space on the right end of the screen. Worse yet, they'll nest other panels into that. It's not hard for a person to make a mess out of a workspace if they're clicking without thinking.
WildWestDesigns
I get a lot farther along opening something like an Adobe Illustrator .AI file .....
Oh no, I'm talking about flawless files that are still bunk for physical production that I would do. It's a lot easier to tell them that I need to know what the font is (or have it converted to outlines) compared to saying, looks great, but still need to make alterations in order for my output to look great as well (and that can actually happen with even simple files as well, because they don't know min/max values that certain objects should be, especially with regard to text). There is having a very nice illustration, but having that very nice illustration to also work with physical production (and the icing on the cake is that those "designers" that more likely don't have any knowledge of all the processes that those files are going to go through, nor know anything about those specific process and how to design for them will say that their design should be uses "as is" and if anyone tells you differently, they don't know how to do their job).
I believe the properties panel is another spot that will do that as well, but I could be remembering wrong. When someone is used to a function to be in an very specific spot, that's hard to break with muscle memory. Plus, there is time that it takes to get used to having to scan when it changes to see what is available at any given time. If I'm not mistaken as well, it doesn't show all of the functionality within a specific context, just the most used ones (which may or may not apply to the user in question). Now that can be changed, but again, power of defaults and how trivial it is to do said change.
The whole making a mess out of the UI, yea that's been a thing for a long time. Not as bad as doing it with Blender, but it can pretty bad.
Now, having said that, I firmly believe that people should be willing to adapt within a reasonable amount of time and if making a living off of tools, should be fairly robust in knowledge of it's feature set to help morph it to your own needs(now if it's more of a visually minimalist setup by default, that's something else). Be it from changes from one version's UI/UX to another or between one vendor to the next if having to switch for whatever reason. That's just something that may keep someone from wanting to move on though.
Bobby H
Arial Sucks.
From my own 30-plus years of working with other graphics people, either as co-workers or outside designers involved in the production chain, I've seen a pretty wide range in the level of competence.
The ones who have a real passion for their work go out of their way to dig a lot deeper into creative applications in order to make their work better and more efficient. On the opposite end are those who memorize the bare minimum number of steps to get a task completed; they'll only memorize (not learn) something new when a situation forces them to do so. They're not going to learn or experiment voluntarily. Most graphics workers fall somewhere between those two extremes.
No one is going to truly master using Adobe Illustrator or any other creative software application for that matter unless they're willing to dig deep into it and experiment. I have few complaints about Illustrator's UI getting in my way. But I also use a lot of keyboard shortcuts so I don't have to click around as much in tool bars, panels or dialog boxes. It's not hard for me to keep a workspace organized. It's also pretty easy to reset a workspace; plenty of Illustrator users haven't bothered to learn that simple step.
Unless it's a money thing, I don't understand someone hanging onto a version of Illustrator 14 or more years old. If the reasoning is solely UI differences I see that as very small potatoes. I'm hopping project elements back and forth between CorelDRAW and Adobe Illustrator on a frequent basis, negotiating the big differences in their UI designs while doing so.
It's the same situation when it comes to amateurs using Canva. Lately I've been trying to convince clients who use Canva to give the Affinity App a chance so they can create more production-friendly artwork. It's free and it's sort of related to Canva. So far I haven't seen any of those clients bother. This situation points to the larger problem of many graphics people not really knowing the text book details of this craft/profession. I'm talking about the cerebral stuff that isn't included in the software, like knowledge about page layout, typography, color theory and on and on. It's possible for someone to learn that stuff without taking classes at a college or trade school. A bunch of it can be learned online for free. Even with that available plenty of "designers" won't bother to make the effort.
WildWestDesigns
We have about the same amount of years. I started in 94.
Write scripts (of course, it would be better if it had a headless operation, but alas it doesn't) all the time. I have small mini programs (some in C, some in C++, some with GUI, some with not) all streaming the procedures that I need to do. A lot of in house tools, I believe for a competitive advantage, most people need to have in house tools, but I digress.
And that's why the power of defaults exists. However, I said that "I believe...", that surely isn't reflective in the current situation. I think people should be more knowledge about computers, while there is a good portion of the "digital native" group that doesn't even know file trees.
Absolutely, as they should. Of course, one is also limited by what Adobe allows one to do. Take "Actions" for example. They are great, but only able to do what Adobe allows one to do. Not being able to run Adobe products headless is another hit as that would allow for scripting of tedious operations without having to spawn the GUI, which would mean doing things even faster.
I've given a few that aren't directly related to money. All of those are compounded with the SaaS nature of the software as well. There are a few things that would trump those, however, even that can be mitigated (I did, most customers didn't know that I ran Linux, imagine getting 1st party support for Adobe on that (outside of Substance Painter, which they bought)).
While there needs to be a certain level of feature set in software (or have workaround to get it), being more production friendly requires knowledge, not just having a specific tool.
And with "AI", they definitely won't know how to do things. Why more and more, while I do like my tech, I'm doing more analog when able to. However, I would also submit that those that don't care to gather the knowledge would also not care to know that specific software in and out. They tend to go hand in hand, until the laziness plays a part.
netsol
at one time, they all gave you a choice of standard or "classic view"
too expensive to program that way now
plus, more often than not, the design team may have never actually USED the program they are updating. so why bother to keep features you have never seen?
Johnny Best
I am a Mac user and bought Illustrator the first year it was out, also Aldus Pagemaker and Photoshop some tears later. Bought the upgrades all the way to CS6 and then decided that was enough spending for me.
Still use CS 6 but on my old Powerbook with 32bit software, When I purchased a new Powerbook some years ago the CS6 would not work with their new M chips so I purchased Affinity Designer and Photo and have learned those. I figured I paid my dues to Adobe.
WildWestDesigns
Rosetta 2 didn't work for it? It may have been deprecated/removed by now, but a few yrs ago, I would have thought it would still have been around.
WildWestDesigns
Well that was one of the reasons for "legacy bloat". Some legacy files, could actually be using some of those legacy features, now those old files are dead in the water. There was an issue with Flash/Animate over that very thing as well. I think it was also during the time of the Dolby kerfuffle, but not directly related to that.
