mitsfreak12
Silly, but this should be an easy fix. Hi everyone, hope someone can help as I ran into a dead end and wasted so much material test printing it.
ISSUE: An Illustrator root file created in vector format. File has a gradient feature that consist of one pantone red 1797C. On the gradient slider, one side has 40% fill and the other 100%
PRINT ISSUE: GRADIENT comes out of the printer with two distinct color only, the lighter and the darker pantone.
PRINTER = MUTOH VJ1614 ECOSOL
RIP = ONYX POSTERSHOP VER X10
TRIED FIXES
1. Typical fix = flattened file and converted to tif/jpeg/pdf/psd/eps and imported it as a link.
2. Converted to CMYK and also RGB
3. Turned off "all ICCC profiles" in ONyx X10 rip
4. While saving as an EPS file in Illustrator, turned or selected "compatible gradient and gradient mesh printing"
and a lot of other ways of trying to fix it and still coming out the same - a two tone print instead of a gradient.
Hope someone has other ideas or if anyone experienced it and found a solution. HELP![Pullingouthair :frustrated: :frustrated:](https://signs101.com/images/smilies-orig/standard/pullingouthair.gif)
TRIED FIXES
