Ink Adhesion Issue
DSC
OCE 250gt
256 inks cmyk
Printing on the smooth side of P95
We had an issue where the ink was coming off.
1. We printed on the back side(smooth side)
2. Then laminated the back with white oracal 710 white RTA, .25 bleed
3. Then, when we flip the acrylic to cut the bleed off with a blade, the ink comes off the edge of the acrylic..
4. When taking the vinyl of of the back the entire print nearly comes off.
Any thoughts?
Maybe we need new LED Lamps?
Thank you in advance!
Brian27
Any thoughts?
Unless you've previously printed on P95/Clear without adhesion issues, it's probably just an adhesion issue and not your equipment. Our roland would do the same thing.
We've been using Supply55 AP3155 with huge success. Even when we heavily dilute it, it still works great.
