input on logo
O.T.P. Signs
Feel free to comment on this logo. It is for a new development in which the houses begin at $450,000. It will be used for everything from entrance signs to letterheads etc...just wanted to see what else others think.
Shovelhead
How about an oak leaf....
instead of the whole tree?
I don't see a need for the stream.
Lose the white outline on the lettering.
Script is hard to read.
Kerning is too wide on "OAKS".
Rick
I agree with Shovelhead on the type. It also needs more contrast on the type.
Robert
Hehe, $450,000 won't even buy a run down townhouse/condo out here anymore. I bet it's a freakin MANSION out that way though. There was a townhouse across the street from me that just sold for over $600,000. a TOWNHOUSE.. with SHARED WALLS.... Man this state blows!! lol.
O.T.P. Signs
read the script its the oaks (meaning 2 trees) at Haynes creek (hence the need for the brook) did you look at the image? As far as the white line that was my bad and I agree it needs to be reduced. And Robert you need to move...Rick give some examples on the contrast what do you reccomend?
Rick
I think Shovelhead means you do not need a literal visual interpretaion of the name to get the point across.
On the contrast issue, you have too many things going on in the backround. If this is a logo and a sign, the copy should pop more. You can keep your image if you prefer that, but place the type away from the image, and give it a color that will go well with the backround it will be placed on. You need a different script, and try googling "The Oaks logo" there are a few examples of how other designers did it.
O.T.P. Signs
T-he...the, Hhh-aynes...Haynes...I know, Im just hacking on ya. i guess I more concerned with the colors more than anything, they kinda make me wanna vomit.
Pro Image
Just an observation, Re-kern the OAKS closer together move "at" under the A in oaks in the dead space. Strech out "The" a little and move Haynes Creek over to the right somemore to center it up in your boarder. Oh Move the word "OAKS" to the left and center it in the oval, and get rid of the white outline. Like I said just a observation I like the colors too.
bob
Soften the border, it's bolder than any other element. Try a smaller outer with an even smaller inner.
Lose the orange outline around the right-most tree and 'S' in 'OAKS'. If they want to overlap a bit, let them. The orange border makes it look like you're trying for a collage.
Add some dimension to the trees, the flat green is a discord with the rest of the background. And make the trunks and branches not green.
Lose the white outlines around the script. Tighten up the 'Ha' in 'Haynes.
Make 'OAKS' just a taste, a small taste, bolder and close up the 'A' and the 'K'. The white outline on 'OAKS' remains to be seen. Sometimes it works, sometimes it doesn't.
