Installed new Ink Pumps - Roland SC 540 ... 2/3 Failed from the start ... reason?
96XP
It's been a few months, and meant to post my question sooner: that if anyone else had ever experienced this same issue, and what reason (diagnostic) there could be for the new pumps to be defective.
'Generic Roland XJ-540 / XC-540 / VP-540 Solvent Resistant Ink Pump - 6700319010'​
A few months back, I decided to order 3 new ink pumps, just to be prudent.
After first install, I had noticed they were very noisy, a shriek I'd never experienced before when they were actuated.
Two of the three that were installed didn't do the job - and my caps were: floating ink/not draining, and that was the initial cue.
That said, some heads got temporarily clogged as a result.
I then removed them, opened for inspection, then reinstalled, to no avail. Ended up putting the old pumps back in as they were still functioning.
Any idea what part is faulty? Perhaps the 'U' shaped tube within the pump? Should I swap the tube for the old?
Thanks for reading.
96XP
WHERE DID YOU PURCHASE THEM?
perhaps you got chinese look alike pumps?
sign-in-global - I see they are now advertising "Improved Roland Solvent Resistant Ink Pump". They must have skipped the quality control phase on my order. Neither do they have OEM. Still curious what failed in the unit. And they are fascinatingly simple in design.
They might not have enough grease where the cams make contact with the tube inside the pump. If there's too much friction, you'll hear those screech noises.
96XP
Hmmm, I did observe a small amount on the old pumps, and looks the same color/texture as Lithium grease. Am I correct, or is it something else?
netsol
the answer might be the same as my garage door openers.
if you take a can of food grade silicone and get a little splash of it on the grease it will thin the grease out a bit.
(this assumes the silicone and the grease use a similar solvent.
  • Agree
Reactions: 1 user
netsol
vanderj is assuming not enough grease.
i am assuming old stock (but perfectly good) but grease has thickened.
  • Agree
Reactions: 1 users
damonCA21
That is a good reason to avoid generic cheap chinese copies and use original parts where you can. Its quite possible as netsol says they greased them and the grease has dried out and seized them. Compare them to your old ones and see if they turn as freely, and also check they give suction when turning
96XP
Didn't have time when I began this thread, however here are a few reference images comparing the new with the old.
Not sure how much grease there should be on the inside, though perhaps someone can offer direction on how much and where to pack it in, as I'll give it another try.
96XP
... images continued.
96XP
I agree with your statement, though nearly everything we consume (except food) came from there. Just looking around the studio here, it's hard to find anything that has parts manufactured here in the Western World.
Side note:
Does anyone recall a show titled Fight Back! with David Horowitz? Or am I just showing my age. Lol
We need a new version of what he did.
  • Agree
Reactions: 1 user
damonCA21
You just need a decent smear of lithium grease around where the inner part rubs against the casing on both sides. From the photos it looks like the new one has barely any in there
  • Agree
Reactions: 1 user
damonCA21
There are different qualities of things made in China though. Items produced for western companies are generally much higher quality and better made than those they produce to sell directly which are just made as cheaply as possible
96XP
In fact, it doesn't have any in there at all. Pretty pathetic @ the manufacturing end.
I'll do as you suggest - and report back once I have a moment to get it swapped and tested.
Q1: Should I smear some grease on the internal plastic hose as well, to relieve the friction of the rollers contact with it?
Q2: There is nothing in the maintenance manual to suggest priming the pumps, though would it be beneficial to do so?
netsol
take a spray can of food grade silicone with a straw
spray a shot on the brass(/) bearing around the shaft.0)
where it come through the motor casing
