JGGraphics
For example, I am going to peel off the decal on the left, and replace it with a new Salvation Army logo that I'll cut out of translucent red Hexus vinyl. It'll be 24" x 29" in size.
So I asked Grok how much I should charge this client, and Grok said I should charge between $350-$650 for the job. With the breakdown that reads as follows:
Is it just me, or is this price gouging?
Breakdown of Costs and Pricing Factors
1. Material Cost (Hexis/Hexus T5033 Translucent Vinyl)- The size is 29" x 24" = ~4.83 sq ft.
- Hexis T5000-series translucent vinyl (T5033 is part of this line for light boxes) typically costs $1.50–$3.50 per sq ft wholesale, depending on the supplier and roll width.
- For ~5 sq ft you'll use (including waste/bleed), expect $15–$35 in raw material.
- Add transfer tape, application fluid, and minor supplies: $10–20.
- Removal of old decal: 30–90 minutes. Old vinyl on a light box can be stubborn (especially if aged or on acrylic/lexan). Heat gun, steamer, or adhesive remover often needed.
- Design/prep/cutting: 30–60 minutes (assuming the new logo is provided or simple vector work).
- Application on light box: 30–60 minutes. Translucent vinyl on a backlit surface needs to be bubble-free and evenly tensioned for good light diffusion.
- Total shop + on-site time: 2.5–5 hours.
- Typical vinyl/sign installer hourly rate: $50–$80/hour (shop time) or $75–$100+ for on-site work.
- Many shops price vinyl graphics at $8–$20+ per sq ft installed (higher for translucent/backlit work due to precision and material).
Suggested Pricing Tiers
| Scenario | Total Charge | Notes |
| Basic | $350–$425 | Simple removal, straightforward logo, you're local/low overhead |
| Standard (recommended) | $450–$550 | Full service, good profit margin, covers potential issues |
| Premium | $600–$750+ | Complex logo, difficult removal, travel, rush job, or high-end client |
Tips for Quoting
- Charge separately if possible: e.g., "$X for removal + surface prep" and "$Y for new vinyl fabrication & install."
- Minimum job fee: Many shops have a $150–$250 minimum — this job easily exceeds that.
- Add-ons that justify higher price:
- Travel/time to site.
- Surface cleaning/prep (especially if old adhesive residue remains).
- Proof/revision of the design.
- Warranty (e.g., 1–2 years on the install).
- Market context: In many areas, full light box face replacements (new substrate + vinyl) run much higher ($800+), so just replacing the vinyl is a good-value service.
