Is it worth making this in-house?
tulsagraphics
I need to get (or make) a new sign face for this customer, but I haven't messed with trim cap installations before. I assume it's the same method as channel letters (doesn't seem too difficult).
I guess my real concern is making sure the thing actually fits.
- Are faces usually the exact size of the return? Dimensions are 96" x 24".
- What's a good substrate for this? Maybe a .150 polycarb?
Note: I used to refer these types of jobs to one of the local sign fab shops, but they've all closed down (nearest shops are about 60-70 miles away). Is it worth cutting my teeth on this kind of work? Or better to sub it out, sight unseen?
polycarb should be fine, for me its actually ideal on larger faces.
yes its the same as an acrylic letter face ....EXCEPT you cannot use the regular channel letter weld-on glue for acrylics as it won't bond to the polycarbonate.
we use the weld-on 58 two-part polyurethane adhesive.
and the face is typically cut slightly larger than the returns, for looser-fit. the jewelite will cinch on, but you can't bow it out if its too tight.
i'm usually a ~.090" offset from the channel letter returns.
Reactions: 1 users
tulsagraphics
Ah! Good to know. Thanks for the tips!
Johnny Best
Do it yourself, You will know how to do it next time it comes up since the other shop is closed up.
Bobby H
Arial Sucks.
Lexan (polycarbonate) is more flexible. If it isn't secured really good to the return it will be likely to blow off (just like the previous face). With the existing channel cloud shape having radius corners it might be necessary to get a face area pattern from the existing aluminum return. Or just take really good field measurements. Otherwise the new trim-capped face won't fit precisely.
JBurton
Signtologist
I vote for polycarbonate, 1/8" overall width, channelbond or weldon (I can't recall what numbers, but we use a thin glue to secure, then a thicker glue for a more permanent bond.). Get a good rubbing of the face to transfer to the plastic, then use a jigsaw to cut out. Sometimes it makes more sense to remove the can, lay it face down, and get a tracing.
IF you can find a UL sticker with an E number, you can look up the original manufacturer, and if it's a wholesaler/fabricator that made it several states away, they'll usually work with you to get the original files to cut the plastic from, and save you all the headache of a pattern/jigsaw. Here's the UL website to lookup E numbers: https://productiq.ulprospector.com/en/search?term=e142146
tulsagraphics
Oh nice! I'll check that out. Thanks!
