Nothing can compensate the skill of the person, applying a wrap, cutting or whatever.
That video made me laugh. The contraption they sell for cutting the lines when wrapping a car. I can do it faster and better with naked exacto knife. That's what i use. Many years ago when I saw for first times my friends working all time using naked blades in all situations i did not get it . Now i use almost always the same.
In all other cases - Non folding exacto knife, where pressure is needed. I cut by hand faster shapes in 2-4mm expanded PVC board than the time it takes me to program it on the CNC. In fact a neighbour business that uses my CNc services once told me that never he received such perfect cut from the time he had his business on a complex shape. Yep, by hand.
Same goes for backing foam for photos. A steel ruler upgraded with non slip rubber one side and a steady hand.
But back to the stickers. 1-3mm between them and when printed lift at once that area. Then they are easy to peel left on roll or cut to bands or cut to one by one.
Every not necessary operation is a waste of time or a
sign one does not know well his job.
Which in fact turns to the fact that the bigger the sticker goes the more shows if one does not know the proper way to work.
I am a one man shop and i easily apply anything up to 2 meters long. And very fast. In fact what i apply now for 15 min before an year took me 1 hour at least 2 people. The key is a heavy duty spray pump that throws a lot of water, and to key the exact amount of soap for the specific job. Of course i can apply dry, but avoid it, except for stickers.
So for me is a very strange thing to waste time to cut the back lining of the sticker to 2 pieces, especially when if applied in the right way that will be bothering me instead of helping me. Especially that i always peel the backing from the sticker that lies flat on a surface.
I know you all know, but for the sake of people that dont know. That's my way of applying stickers from small to 5 meter vinyls. And by the way i learned it from Youtube. at the time.
1. Spray hard on surface using garden pump they use for fumigation. 5 liter deposit.That prepares the surface and cleans it from the floating dust
2. Lay immediately the laminated side of the sticker or the transporter tape of the vinyl, to the wet surface. That keeps the sticker like glued so its easy to work and avoid to fold. And keeps the water from surface from evaporating.
3. Peel all the backing. Even if 3 meter long. Or 5.
4. Now the pump comes into play again and i wet the sticky side with a lot of water. The key here is the water to be distilled and the soap to be good as that makes the water stick to the film
5. Alone or with a helper i take it out from the surface, flip it , position it and place it. Depends how many drops per liter soap, its easy to reposition or harder. Depends if small letters or big sticker, or sunny day outside or cold day inside i adjust that.
6. Take out last bubbles and if its a vinyl letters take away transporting tape.
Thats it.
And yes i use the pump even on small jobs. Why pup a damned bottle 10 times when you pump the big pump only once. And to tell you the truth i am saving for an electric battery spray gun like the Graco. The one they use for airless painting. Instead of paint i want to throw just water and do it even faster. Battery operated as i do a ot of car wraps outside, still not big enough to have own garage for that.
