Job Batching Software
Hey all,
I have a software related question and was wondering if anyone has any insight into this topic. We are looking for a way to take all of our sign orders and divide them by material type to make nesting our jobs more efficient.
For example, 2 orders come in. Order 1 has signs on High Intensity and Diamond Grade reflective. Order 2 has signs on High Intensity and White Vinyl. I am looking for a program that has the capability of taking those 2 orders and giving me a list of all the High Intensity signs we need to print, line by line, even though they are coming from multiple orders. Is anyone using a software that has this capability? Any help if greatly appreciated.
Thanks.
Brian Tickenoff
Sounds like you're looking for workflow automation... You can go with something robust like Switch or Esko's Automation Engine. tFlow may be another option (I hate it TBH) but I'm not sure if it will separate/gang like you're talking about.
There is probably something similar and more budget oriented but I'm not sure what that is currently.
Pauly
Printrade.com.au
Do you have a budget?
Because what your asking could add up quite a bit.
We would do this in enfocus switch and Griffin. But you'll need to build the workflow from scratch.
You could also do this in Caldera as it has as it'll auto nest for each stock. You won't get your list though.
In Print
I am looking into this as well. We are looking for auto nesting, double sided automation and material type batching and probably more. Looking so far at print factory which is more plug and play and is your rip as well. Not sure it will give list but you can build a hot queue per material and it send to printt once full… also just started to look at Switch but as mentioned above you need to build it out. I think in the long run it actually comes out cheaper than Print factory and might give more functionality however print factory allows you to not be reliant on onyx which has some kinks I wish it didn’t.
