JV3 not printing til refresh
serverjohn
Hey guys and gals,
What does it mean when my printer only prints the first line, then moves the head like it is printing but nothing comes out until the head goes back to the capping station. After it refreshes the ink supply it print one strip then nothing. This happens across all the colors. Any help is appreciated.
Thanks,
john
genericname
A properly functioning printer should still be able to print in uni-directional mode.
You might have a lot of crap on your encoder strip. Take a look at it, and wipe it with a damp, lint-free cloth, making sure not to stress it or otherwise bend it.
Failing that, blow some air through the encoder sensor on the back of the carriage to free up any debris that might be messing with the sensor's readings.
Normally would sound like extreme ink starvation, but not across all heads.
J Hill Designs
is it printing correctly or does it make printing passes where nothing prints? if prints are coming out correct you are prob in uni mode as stated
serverjohn
Thank you for your quick responses. I printed a few things today just fine. Then I started this job and it all the sudden started doing what I described. I have attached a few pictures to show what it is doing. It is not printing the image properly. It should be solid colors.
serverjohn
I am not quite sure where the encoder strip is. That being said, nor do i know where the encoder sensor is. I have the carriage cover off but i am not sure where those items are. I could take a picture if that would help.
J Hill Designs
its a clear looking strip that runs the length of your printer head carriage
fyi search for cleaning encoder strip - DO NOT USE PRINTER CLEANING FLUID
ChicagoGraphics
I had the same problem last year but not as bad, clean your clear encoder strip with a 50/50 of alcohl & water, rub lightly then see if that fixes it if not shut your machine off and remove the cover to where your heads are, there is a sensor that reads the encoder strip that need to be removed and cleaned and put back carefully. That should fix the problem your having.
serverjohn
I feel a little stupid... Does the encoder strip run the length of the print area? Or is it physically attached to the carriage? I have attached a picture.
thanks,
john
genericname
Yep, back there. Runs the length of the printer, though it's not attached to the carriage. There's actually a small sensor on the back of the carriage that cups over the strip. If you look closely, you'll see that the strip isn't actually clear, but has a multitude of tiny vertical stripes on it. Those stripes break the sensor's beam, letting the carriage know how far along on the path it is.
If you stick your head in there while it's not running (but still on), you should be able to see the red light emitted by the sensor at the back of the carriage.
