The printer had not been in use for quite a while. It's running Triangle JVV inks on the Easy Fill bulk ink system (SS21 compat inks). I am just trying to bring it back to life...
I've tried the following processes:
- Numerous nozzle washes ranging from 1 min - 24 hours (turning off the machine while head is parked on cap)
- Head swabbing (always one direction using proper cleaning solution soaked swab)
- I've performed several ink fill-ups
- I've pulled ink through the dampers and head by way of the waste lines (opening valves through menu)
- Today I swapped ink lines to the manifold to troubleshoot head vs. ink problem (the head channel comes back to life!)
Parts I've replaced:
- Dampers (but the buttons aren't "depressed")
- Filters on the triangle bulk ink system (skywalker 45mm type)
- Wiper
- Capping station
- I've confirmed pump works (drain hoses weren't in the waste jug and made a big mess)
Anyway... here's the photos:
The first 3 below were trying various nozzle washes & ink fill up's....
Then in these next 2, I thought to swap damper #2 (Cyan) with damper #3 (Yellow) just to verify if the reason the ink wasn't coming through the head on channel #2 was due to a head problem or an ink problem....
I'm no pro, but it looks like after the swap it wants to start printing on that channel, indicating some sort of ink/line problem going on here?....
Through the various test draws, it seems that all channels from the head WOULD work if they could get ink to them, no?
I've tried so many things now I'm not sure what do do next. Feels close to a solution though
- Wiper
- Capping station
