JV330-160 Prints are coming out longer than they're supposed to
Blazing_Murph
Hey All,
Ive noticed recently that our JV330-160 is stretching our prints slightly in the feed direction. Ive tried adjusting Feed Compinsation as well as heat and take-up tension but im still seeing it. I was wondering if anyone else has had this issue or if there is a solution that im just not seeing online. Any information would be helpful!
Thanks,
Murph
  • Agree
Reactions: 1 user
How long are the prints you're running and how much longer are they coming out? I'm not sure what the official spec is on the 330 but most Mimaki printers and cutters will say to expect about +/- 1/8th" of deviation over an 8 foot print.
  • Agree
Reactions: 1 user
Blazing_Murph
just ran a large ganged up job, which may be throwing the numbers off a bit. Pieces that were supposed to be 40" were coming out about 3/8" to long. I just ran an auto Feed Comp and DAS test and then ran a 3' ruler vertically and its +/- less than a 1/16" so that may have helped to fix the problem. Im currently running some longer pieces and i'll keep you posted. Thanks for reaching out, hopefully the auto test and cleaning the sensor was the fix.
Goooost
Hey All,
Thanks,
Murph
I have this issue with a Mimaki UKV100-160. If I print 100in I might get 98 or 102. Unfortunately I dont have an answer for you on this one. My suspicion is that it's the take up reel doing its own thing regardless of the print advance or how much banner is already wound up.
cornholio
Happens all the time with most printers. That's why you can set dimensional correction factors in the rips.
  • Agree
Reactions: 1 user
Caren Hines
As Cornholio said, it happens with all printers.
If you are using Onyx, this guide might help you adjust your dimensional settings to resolve the sizing discrepancy:
Good luck.
According to HP, for our Latex 365:
As a general rule, you can expect the following percentages of shrinkage:
● Banner: less than 2%
● Self-adhesive vinyl: less than 0.5%
Meaning HP would consider a 10 foot wall mural being 1/2" short on one panel to be acceptable tolerance. Good luck lining that up!
They've replaced multiple parts and it's still an issue for us. I'm going to try that dimensional correction, although our shrinkage doesn't seem to be consistent.
Smoke_Jaguar
I've found that to be more down to materials than machines in my experience. Especially anything that uses heaters, drifting gonna happen.
Sofia Lucas
Blue Dot Signs
Stretch in the feed direction only points to media advance, so you're on the right track with feed comp. Make sure you run it on the actual media at full production temperature — a cold calibration won't match real conditions. Also check the pinch rollers for dirt, wear, or uneven pressure, since slipping rollers stretch prints exactly this way. And measure your test prints after they've cooled, not straight off the heater, because media can relax a bit as it cools and throw your readings off.
