I'd totally opt for Laguna if they're local, that's pretty awesome!
A couple of notes:
See if you could exchange the 1/2" collets for more 1/4", not a lot of good
sign tools are 1/2", unless you intend to do some wood working. Though I'm suddenly wondering about HDU and a 1/2" bit, but I only have a ball nose in that size at this point... Are you just using this for your channel letters, or do you plan to branch out to stuff like HDU?
Also on collets, if you break a bit in the 3mm, it'll likely bugger the threads, potentially to the point of the damn thing actively breaking bits when tightening the collar. Have spares and inspect them after breaking a bit. I broke at least 2 bits figuring this out. Haven't had the same issue on larger tools.
If I could do it again, I'd have hired someone to unload and position it. It took all afternoon using two forklifts, car dollys, and two bottles of tums.
The ballscrews on the shopsabre are pretty cool, but jeez is that thing loud at full speed. Also maintenance on rack and pinion is basically blowing the chips off, the ballscrews are a lot more cleaning and greasing.
Assuming you already have design software, have they recommended a CAM software? I guess you probably already have one, but if you get tired of subscriptions, sheetcam is excellent with pretty great support.
I wish I had some input on Laguna, but surely someone around here has some. From what I've seen, their machines are industry standard and they make a lot of them, so they should have stellar support.
