Laguna smartshop me
Bradley D
www.jigsign.com
Has anyone used a Laguna SmartShop M2 5×10 router with a 6 HP HSD spindle and vacuum hold-down?
I’m considering one for sign fabrication and would appreciate any firsthand feedback on the machine and Laguna as a company. How’s the reliability, and what has your experience been with their service and support? Would you buy one again?
JBurton
Signtologist
New CNC time! How exciting!
Do you already have 3 phase to your shop? This is a significant expense to consider if not. (Usually it's the vacuum that will require 3 phase, but occasionally the router needs it too.)
Do get the automatic tool changer! No matter what you think, you'll love it when you need it.
Are you getting misters added? Pretty well required to cut aluminum.
Does it have pop up pins for sheet registration?
I didn't get a laguna, ended up with a shopsabre, and while I love it, there was a somewhat significant hiccup in between installing this one and running the old one for the last time. They weren't the most helpful when trying to figure out little things, like turning off the mister between cuts, or reducing acceleration to prevent lifting. Shopsabre was more focused on cutting wood rather than aluminum, things may have changed since they started selling lasers to.
Bradley D
www.jigsign.com
SS2 Collet Kit SS2 Collet Kit
SS2 Collet Kit
ER32-10mm-1 pc
ER32-1/4"-2 pcs
ER32-3/8"-2 pcs
ER32-1/2"-3 pcs
ISO30 TOOL CONE ER32 ISO30 TOOL CONE ER32
*8 total
10HP VACUUM Pump 10HP Vacuum Pump SS25-6" - 285 cfm
10HP STOCK Regenerative Blower Vacuum Pump
220 VAC, 3 PHASE 5-6" - 285 cfm
Includes filter housing, filter fitting
15HP DELTA MS300 VFD 240V, INVERTER High Frequency
(0-1500Hz)
15HP DELTA VFD,INVERTER
CNC start-up/training - 2 days For new machine sales CNC
start-up/training -2days
CNC start-up/Training - 2 days for new machine sales.
- This is a onsite Training at your location.
-Installation must be completed within one year of the
machine's invoice date; otherwise the installation will be
voided.
CNC Shipping Note
Important Message - CNC, Plasma, Laser and other large
industrial machinery ships via flatbed air-ride trailers. The
receiver (customer) is required to have a forklift with 72 inch
forks or schedule a rigging company to offload their machine
upon arrival.
CNC To Be Wired For Single Phase Power
To Be Wired For Single Phase 220V Power
Bradley D
www.jigsign.com
I seriously considered ShopSabre too, but I really wanted rack and pinion. It seems simpler to me, and I don’t need extremely high precision for the work I do. I’ve also been told it allows higher travel speeds.
ShopSabre was also quite a bit higher in price, with a longer lead time and shipping from Minnesota. The Laguna will be assembled and shipped locally.
Laguna’s customer service has made a good impression so far. They’re including two days of training at no charge, and being local is a big plus. Hopefully, that will make it easier to get technical support quickly if I need it down the road.
JBurton
Signtologist
I'd totally opt for Laguna if they're local, that's pretty awesome!
A couple of notes:
See if you could exchange the 1/2" collets for more 1/4", not a lot of good sign tools are 1/2", unless you intend to do some wood working. Though I'm suddenly wondering about HDU and a 1/2" bit, but I only have a ball nose in that size at this point... Are you just using this for your channel letters, or do you plan to branch out to stuff like HDU?
Also on collets, if you break a bit in the 3mm, it'll likely bugger the threads, potentially to the point of the damn thing actively breaking bits when tightening the collar. Have spares and inspect them after breaking a bit. I broke at least 2 bits figuring this out. Haven't had the same issue on larger tools.
If I could do it again, I'd have hired someone to unload and position it. It took all afternoon using two forklifts, car dollys, and two bottles of tums.
The ballscrews on the shopsabre are pretty cool, but jeez is that thing loud at full speed. Also maintenance on rack and pinion is basically blowing the chips off, the ballscrews are a lot more cleaning and greasing.
Assuming you already have design software, have they recommended a CAM software? I guess you probably already have one, but if you get tired of subscriptions, sheetcam is excellent with pretty great support.
I wish I had some input on Laguna, but surely someone around here has some. From what I've seen, their machines are industry standard and they make a lot of them, so they should have stellar support.
Bradley D
www.jigsign.com
I’m starting to lean toward the ShopSabre RC model. It has a 5 × 10 table, a 220V vacuum hold-down system, and an available 5 HP spindle. The RC looks fairly beefy to me, and it uses rack and pinion, which I like.
The price also came in about $7,000 lower than the Laguna, so that has definitely piqued my interest. We mostly do light cutting and detailed work with a lot of 1/8-inch bits, so the RC looks like it could be a good fit for our shop.
One thing I didn’t particularly like about the Laguna was the file-transfer process. From what I’ve seen, it appears to involve carrying files over on a USB drive, and the file-import features seem fairly basic. There may also be an Ethernet option, but I haven’t confirmed that or how it works.
I’ve heard good things about Laguna from a friend, but I haven’t heard much firsthand feedback about ShopSabre yet. I’d be interested in hearing from anyone using an RC for sign production, particularly for detailed cutting in acrylic and aluminum.
JBurton
Signtologist
Sorry, we were out of the office for veterans day and I've been playing catch up.
Ya know, I considered networking my router pc to the production drives on the network, but I also considered what a windows update would possibly do to the machine, and have opted for a fully airgapped setup, where we save to a usb and march it out there. For me it's a 75 ft walk, but it is frustrating when the usb drives decide to not actually save the file, or when you need to make one change. Just something to consider.
(Also, not sure what controller's Laguna's run, but it is important to note that my shopsabre runs off a wincnc expansion card installed in a pretty standard PC setup. This keeps the PC from interrupting the flow of info from the PC to the controller by acting like a buffer or extra CPU in a sense. It makes for a much cheaper buildout and replacement parts, but it does mean you're under microsoft's thumb. I'm wholly unaware of how the laguna is set up.)
Personally, if Laguna were in my backyard, I'd opt for them. I've had numerous issues arise, and while they've been quick to resolve everything, knowing that I could march down there and yell at someone would give me a little peace of mind.
