Laminator Suggestions - Newbie
I have been making signs for years, both hand-painted and using various vinyl cutters. Since we are a small design studio, we’ve outsourced all our digital printing, which has usually made up a smaller portion of our business.
Recently, we got a great deal on a lightly used Roland printer (SG-540), and we are now looking to pair it with an easy-to-use, reliable laminator.
I am considering a new GFP 63" 300 or possibly a barely used Seal 54" EL.
I don’t have any experience using a laminator, but after some research, I believe a heat-capable laminator, rather than just cold lamination, would be the better option.
If anyone can share advice based on their experience, I would greatly appreciate it!
JBurton
Signtologist
I would buy a new one over used, at least then you know what issues you're chasing down vs what may have happened to the used one.
I have a gfp, it's fine, not top shelf.
Mefu (I think) is the choice cheap laminator off alibaba, cheaper than new GFP, but it's a copy of a much more expensive machine. If you could wait on one to ship in, it's likely the better deal.
Heat capabilities aren't really necessary.
RighteousDude
Every shop I've worked at that had a heated laminator never used the heat because the heating element died and was expensive/difficult to replace... or they just came to the realization it was unnecessary, so with that said I'd say don't pitch out for a heated roller. I'm co-owner of our own shop now and we just use a Royal Sovereign and I see a lot of people trash talk them but this laminator has been going 5 years without a single hiccup now, I haven't had to do anything on it... I worked at two other shops that used Royal Sovereign before starting our own thing and one shop had zero problems, the other did develop some tension issues we had to fix (just open the side and you can adjust pressure/tension per side with a couple pulleys/sprockets if memory serves right) because it started to skew extra long runs of laminate... come to find out, one of the guys there was cramming 1/8" skid through lowest pressure setting which is probably what threw it off. I think, personally, bang for buck entry level you can't beat Royal Sovereign.
laertes
We've been using a Kala Mistral 1650 for years and have never had any problems. A key advantage of this machine is the automatic roller calibration.
The heating function is only important for UV printing, as it softens the adhesive and compensates for uneven surfaces.
defarge
I’ve been using a seal 62” base model since 2008. It is really a workhorse. I haven’t used the heat function in over 10 years.
although the first time he discovers what "silvering" is....
MPrint
We recently got a new GFP 355TH and are very happy with it. We had to upgrade our old Royal Sovereign cold laminator because we could no longer buy replacement parts.
Roll to roll is great, something I couldn't do without now that I have it. The pressure wheel takes a bit of getting used to. I don't use the heat function anymore because I got some unpredictable stretching when I started using it. My fault I'm sure but I can do without it.
New is the way go if you can. If you buy used, you can't be sure about the condition of the machine even if it looks good.
Thanks for all the replies!
Still on the fence, but the Seal is pretty cheap (the guy is trying to retire), and it's only about 1/2 hour from my shop.
For what I'll have into it, thinking of taking a chance. If it doesn't work out, I can always suck it up and buy new!
JBurton
Signtologist
Hey, a cheap laminator can make for an effective (though somewhat cumbersome) applicator in a worst case scenario...
Stacey K
I like making signs
Ha ha! I'm still using my cheap 52" Vevor laminator and I use it to mount prints to sign boards also. Was always going to buy an electric one but never saw the need once I mastered this one.
bsipsy
We have a Kala Arkane 1650 (converted from a Mistral. Thanks Scott!). At first, we got the dual-feed and had tons of issues, but they took it back and replaced it with our current single feed machine and it's been great. Most of the time my operators are able to set it up and start it, then walk away and work on something else until it's done. If you're doing UV printing, you'll want the heat to prevent silvering.
The Kala Arkane 1650 looks like a great machine!
Who's a good point of contact to purchase Kala laminators in the US? I'm in the Northeast (Vermont) if it makes any difference.
MarkSnelling
I used to work for Seal and the Seal EL are good beginner machines. The Base are a bit better (bigger rollers and more bulky). If the rollers aren't cut and you can get it cheap, you'll get a few years out of it for sure.
bsipsy
I'm not sure who the current sales person is. Our contact actually retired at the end of 2025. Since then I've only dealt with the tech Scott. you can send an email to [email protected] and they can get the ball rolling for you.
