Large Flag Mounted Signs
rydods
Member for quite some time.
I didn't make these signs, just pulled them off of the internet but I've seen some like them in Cities I've visited. I don't plan on installing one but just curious...
For the engineers out there, what mounting hardware are you using for something like these applications? Do you bolt completely through to the other side of the wall to a plate on the other side?
I just feel like without some support/chains or cables pulling these up and back towards the wall, they are going to pull away and drop at some point.
I would love to get some insight into how these signs are mounted.
John_Smith
Enjoying retirement in Central Florida
Mounting is always on a case-by-case basis, depending on the building, how it's made, and the age of everything.
A side note: I've never heard this type of sign being called a "flag mounted" type. Is this a location thing?
JBurton
Signtologist
We refer to them as projecting signs. Agreed, case by case, especially when the building is ancient brick/stone. Usually you'd aim for full through bolt, including a dead man on the inside that spans either studs or a significant area of the inner block wall. Corner mounted like that spade sign are especially prone to crumbling the brick upon install if the mounting holes are too close to the corner, and likely goes through a beam. That's not to mention the challenges involved in squaring up two corners, 45'd into a square tubes, plus the face that most square corners aren't perfectly square, so one side is probably shimmed because they made the angle at 95 degrees to compensate.
JBurton
Signtologist
Isn't a spade the symbol of the LBGTQ or something like that? I could be wrong...
I wouldn't think so, simply as the phrase, calling a spade a spade, flies in the face of anything nonbinary.
Aaaaaaaaaaaaand I'm wrong, congrats stacey, your alphabet knowledge trumps mine today!
  • Hilarious!
Reactions: 2 users
unclebun
I asked The Google. Apparently each "Ace of" has been co-opted to represent something sexual.
  • Ace of Spades: Asexual and aromantic people.
  • Ace of Hearts: Romantic asexuals.
  • Ace of Clubs: Grey asexuals or greyromantics.
  • Ace of Diamonds: Demisexuals or demiromantics.
as stated above, its a case-by-case basis.
projecting signs sometimes require blocking installed behind brick/stucco, as the load increases the further you extend-out from the wall.
rydods
Sorry, flag mounted may just be a single pole with a hanging sign.
John_Smith
Since you don't plan on installing one but are just curious .......
"Brick Buildings" are not solid bricks. There is "normally" a 2 or 3" space between the brick "veneer" and the building itself, which could be plywood or CMU (cinder block). So, the only way to find out what is what is to consult with the building's owner or drill exploratory holes.
So, if you ever get a chance to quote on a similar job, turn around politely and Run Forest Run !!!
rydods
My town is pretty strict on signs like these. A company from out of town did a Lume sign (weed store) but it's not very big. Big enough for me to be curious about how it's mounted without chains for additional support and wind load.
