Latex 365 Curing Module Error
Charlie Bucket
Hello Community,
Can anyone help please with the following error:
Description: Curing module 1 (right to left) fault
Error code: 0x1101005
Is this an easy fix and is this something I can buy and replace on my own? Thanks for your help!
balstestrat
Problem Solver
It needs a new heater on that slot.
If you know what to do, you can do it. If you don't know what a torx bit is, you can't do it.
Charlie Bucket
Thank you! I have a torx bit. Now I just need to see if I can find a step by step on how to replace. Any chance you know where I can buy one?
balstestrat
Problem Solver
You can buy it from HP parts store or any reseller.
B4H70-67142
You open the covers, remove old, install new. That's about all the instructions.
that's super weird, i had same or similar issue today and fixed it
module 1 is closest to the screen. End of a heating coil connection had come unpinned from the rivot
yes, you can replace but you may be able to fix in a pinch by popping a few panels to inspect
ozpall
i replaced mine on my hp360 a few months ago, there are 2 version so you need to know which version you have. is not hard but you do have to take quite a few parts off from printer.
in to add: for my heater issue, it was exactly as posted in the link where the coil itself came undone from the rivot.
no soldering was necessary, just had to use a flathead screwdriver to lift the edge of the rivot enough to pull some slack from the coil and wrap-around and then re-pinch it back down.
you shouldn't have to remove the whole curing assembly either. I was able to just remove the two side panels, and the middle cover that houses the magnet for the flip window, and then remove all the screws of the top-half of the curing module to tip-up and expose the curing modules & harnesses. then i simply removed the single heater to rewire the coil. took about an hour in all, and managed to salvage the ~$800 curing module.
balstestrat
Problem Solver
365 only uses the new one that I already posted of.
