Click to Support Signs101 ...
What should I charge on a 18.5" x 240" (20') lexan cabinet face, covered with yellow translucent that will be reverse cut and green (translucent) letters will be applied inside the reverse cut?
If its all one piece...you need to know how much the special charge for out sized lexan will be. Then go accordingly.
But my guess is that you will be purchasing 20 ft of lexan and cutting off 20" of it. That will leave you with another 20 ft piece of 26" lexan. How much call do you have for 24" faces?
Other wise it will be spliced at least 3 times so you still use two sheets of lex and have a scrap piece of 24" x 8 ft.
400 in lex + 100 in trans = 500 at least just for materials
Thanks Techman. Yeah, I realize there will be alot of waste and I'll will have to charge accordingly. I may have 2 - 24" x 96" cabinet face signs to do in the near future, but regardless, I'll be charging for the full width (38").
