Life size cutout
Pideas
I'm printing a life size cutout of an athlete. The sign will be printed on 6mm pvc - total height is about 6.5ft high and 3 ft wide. The usage for the sign will be for taking photos next to this sign.
The legs are spread apart like a football player so there is no pvc between the feet.
What can I use to make this stand up on it's own?
John_Smith
Enjoying retirement in Central Florida
Photos would help us help you. How long will this item be on display? For a one-time photoshoot or for years?
Carpenters & woodworkers would build a wood frame.
Welders and metalworkers would put together a metal frame.
An off-the-wall approach would be to hang the item from the ceiling with heavy duty fishing line.
What skills do you have?
Geneva Olson
Expert Storyteller
that's a really thick board. A customer bought one of those from me recently but he didn't cut between the legs. I want to say he anchored each leg and made a triangle holding it in place. Are you able to do that?
  • Agree
Reactions: 1 user
Pideas
I was in between 3mm or 6mm pvc. I thought 6mm might stand up better because it's sturdier. Maybe I'm wrong about that.
Yes, I was thinking about cutting out semi circle PVC pieces with slits and adding it to the bottom of this to make it work.
signheremd
We usually use something like this (though we buy black ones). We print onto 1/2" FoamCore/Ultraboard or use 3mm or 6mm ACM for outdoors. You just add a bit below the feet to account for the stand.
Pideas
What do you use for the stands?
netsol
can you contour cut a piece of 1/4" plywood (birch if you want to do a nice job)
then take a piece of 3/4" plywood and make a 1/4" dado 1/2" deep
i would be tempted to glue it, but, that would keep it from storing flat as 2 pieces
danno
Negative Ghost Rider, the pattern is full.
When we do "life size" cutouts, our substrate of choice is 10mm alumacore. We would cut out between the legs and add a 4" rectangle below the feet to tie the feet together, in this case we would print a "grass section" to make it look like he is on the field. Then use Mightee Mount graphic stands to hold upright.
FireSprint.com
Wholesale Signs, Stickers, Banners-Free Shipping
Here's what that looks like to have white between the legs:
Without white between the legs, that pose will probably require some custom wood or steel fabrication. Or you could try fabricating something out of PVC pipe maybe?
  • Agree
Reactions: 2 users
Boudica
Basically what we do. But as I said we use ultraboard . And we do it annually with basketball players who are over 6ft tall. Here's last seasons featured player...
Pideas
I like this solution with the white area at the bottom and the hidden easel. Is Firesprint able to create the contour cut line if an image is provided?
Boudica
We've done other styles. This one is for 1/2" PVC, and the back stand is made of PVC as well. you unscrew the bolts, slide in the supports and bolt them back in. I was too lazy/busy to put it together to take a pic, so this is the un-assembled storage mode.
  • Agree
Reactions: 1 user
Pideas
That looks nice and sturdy.
  • Agree
Reactions: 1 user
