Liquid Lamination
Signsup
Where would you find a liquid laminator for Flat Stock. I think they exist somewhere. If I want to direct print onto aluminum and provide some sort of protection, what is the best option without using film. I want to direct print novelty type signs, cut them out with the cnc and then run them thru a flood coater or liquid laminator. Do the make such an animal. I know I can roll on the stuff. but something more automated would be nice.
i have a couple spray cans of frog juice, never used it, though.
we always have a quart of latex (aqueous) laminate for solvent based inks
& solvent based laminate for aqueous based inks
We have one where I work and are getting rid of it. The machine is ridiculous expensive and unless you are running it all day every day it requires a lot of clean up and maintenance. The one we have also required a whole new electrical panel to set up and I understand that wasn't cheap either. Really, it is a repurposed MDO paint coater. Not to mention that the coating is only as durable as your print adhesion. As you can tell I am not a fan.
Grizzly
It’s all about your print!
We've had a wide format liquid laminator since 2006. Great machines for certain applications. They'd work great for what you're doing.
I'm sure you can find a used one. Here are the two companies to look at. I work with both of them and they are great people.
Signsup
Thank you for those links
