Little Coro Pricing
Sabre
Good day guys,
I had to do a hurry-up job this morning for a local company which was 50x 8x10" coro with 2 colour cut vinyl. Am I out to lunch to try for $7 each for these things? The entire project was done on a single sheet of coro, and didn't use a ton of copy.
We haven't done a job quite like this so I dont wanna piss these guys off. They were happy with the mags we did for them, but I just went with the ole Signcraft guide standby on that pricing.
Keep in mind that we're in the frozen north and generally higher than our cityboy competitors. :)
Thanks in advance!
Sabre
Looks interesting. Do you have to enter your material costs for everything as it comes in? Is it for generic jobs or does it cover very much for custom stuff? Looks like it does both print and cut types?
I wouldn't say I'm "having problems", but I do like to check to make sure I'm in line sometimes. I probably do rely on the Signcraft guide more often than I should, but it's an easy reference point so that at least I'm consistent.
Thanks for the reply and link, though. I'll look into it.
Charlie J
It comes with default settings. I really havent changed anything on mine. If you go to the website you can do a free trial. I ended up purchasing mine after using the free trial for about two days.
Pat Whatley
How much lettering to weed? Sounds low for a rush job, two colors, and cut vinyl. Sounds like a lot of work for $350. We'd be at almost that for screenprinting and a five day turn around.
wildside
graphix calc is a good program....
try leaning more into the actual costs involved in your shop, what you have to make, then add in what you want to make, and then add more again
relying on other peoples pricing will only get you by long enough to realize you can't afford shop management software
i have never seen a signcraft pricing guide, but would assume the numbers are all over the place
Sabre
I went with the $7, but added a "hurry up" (setup) fee so it rang out at ~$450 anyway. I'll snag up that trial later in the week when I have more time.
Thanks again
