Logo for Marketing Company
D2S
I have a company I am working that is doing some event marketing and they are looking for a logo for their company. I came up with an idea and they felt it was a little too cartoonish. After sitting down with them they thought it was a good idea but the MH was too cartooney for them. However they love the fony Jiggy Roman so that is why you see me use it a couple of times in the ideas I have. I am working on another prior to sending them for more feedback. I will post that when it is done I was just looking for some feedback right now on these. Thanks guys you are the best.
P.S. the PDF is the one I presented to them, then mainidea.jpg is the revisioned one with a different font trying to make it not so cartoony.
Adam
  • MH1.pdf
D2S
Guys after uploading noticed the color is off its not that lime green it is more of a seagreen and for some reason the quality is bad I must have lowered for size. Apologies
Marlene
what do they do? the logos won't open up for me but from what I can see, they seen overdone and a little too complex.
D2S
they do Event and Sports Marketing and Media Marketing along with Promotional Products. They work with some high profile clientel so they want something professional but at the same time fun. They enjoy cartoony but not to cartoony. Its hard to explain I guess. LOL Thanks for the responses.
ThatGIRL anything you think I can do to make it better or worse? Did you like it better with the second font instead of the original ( I really like the original)
Thanks guys
Pat Whatley
I like the globe thing in the background of the middle one but the fonts are clashing with it horribly. Way too different in styles.
Jiggy Roman is an interesting choice for a marketing company. I'm sure it can be done, I'd love to see what you do with it.
Marlene
maybe try taking some of the elements out of the globe like the meridians. with the outside orbits, it makes the background too complex. The two letters will work better on a globe tht isn't trying to compete with them. the other text Mass Hysteria might work better with a diry font rather than a funky font.
D2S
Marlene before reading your post I had made the background of the globe no longer a gradient and now just a simple color with a slight opacity. Is this working a little better for you?
  • idea3.pdf
Marlene
see if it works without all the lines on the globe as there's a lot going on. just seems way too busy. the concept is good, it's just getting the details in place.
THATgirl
change the lines on the globe to something softer than white and no black outlines on the Letters. I like your idea
THATgirl
I would do a shade lighter or darker than the globe. And if you like the outline on the letters do a lighter outline. The H looks like it's leaning to the left eventhough I know it's not. I would try to angle it just a little bit and I might even play around with the placement. Nudge the H down or over to the left. Not sure how much time you want to spend on this but to me it is a fun design.
D2S
I took one of the spheres away as I think it was too much, I moved the lettering as suggested and lessened the thickness of the outline, I just feel without the outline you lose the lettering.Am I heading in the right direction? Thanks for all the input so far.
  • idea4.pdf
Idea Design
Can you slightly distort the letters so they look like they are on the sphere? That's the only thing that keeps jumping out at me, that you had a good start with the globe and the lines around it, then went, 'oh, sh!t, I forgot the lettering'
THATgirl
the H and globe are too close to the same color. The M is a nice color, can you make the H the lighter shade ? I am probably making matters worse. The globe lines might still be too light. I like this design and think it's fun seeing what changes you are making. bbl I gotta go deliver my a-boards
D2S
based on some of their feelings and the thoughts brought out by you guys, here are the proofs I sent to them this evening. Looking for more feedback.
  • proof.pdf
  • proof2.pdf
Flame
I don't mean to be a wet blanket, but I think you need to start 100% from scratch, as it's just a poor base and it's not going to get much better. Start from scratch, fresh ideas, and..... either pick fun and cartoony, or sharp and professional. Don't blend the two. Pick one, and run with it.
Hope that helps.
