Logo Resurrection
Arlo Kalon 2.0
This is B&W of my logo from 20 years ago. I'm thinking of using it again and am experimenting w/ colors, surfaces, etc. I'm interested in all suggestions - including putting it back in the drawer!
Dave Drane
Well Dave, I think it is the sort of logo that remains timeless. Easily and quickly understood and what's more is usable in all situations without costing a small fortune to reproduce. Maybe you could try some of "today's trendy fashion colours or angle it over and place in a square box.
Arlo Kalon 2.0
Thanks - I consider "timeless" to be a great compliment for a logo. This is only logo in 30 yrs I ever used that was frequently complimented by customers. I'm working on it in a high end 3D program to get some depth to it, and then putting a reflective metal surface on it to get ready to be an Edge print for a van. If you have the time, I'd like to see your suggestion of angling it in a box - what I'm vaguely picturing might be what I need to give this a new life!
Dave Drane
:Coffee: Here is the standard logo I have been using for several years along with the revised version that I used on my screen printed vinyl business cards. Probably a bit more cryptic to read but people who know the logo recognize it straight away.
ApexSpeed
Dave, if your logo sucked, I'd tell you that it would be in your best interests to change it. But it doesn't, so my question to you would be, why change a good thing?
It needs MINOR tweaking to be fine, and I'd leave it alone.
I quickly shortened the leg of the K to give it a better visual balance. It was an optical illusion, but the original version looked like the leg was extending below the baseline, so to counteract that visual hiccup, it was shortened a touch. The bottom of the S was also rounded out a bit. If I were to do anything to this, it would be to draw it in a vector-based program and equal out the line widths and smooth up the curves, but that's about it. I wouldn't change yout identity from what it is now.
doug
ApexSpeed
Ok, I was looking at it again, and the left side was causing some odd tension for me, and I couldn't figure out what it was. It was something in the overall balance of the mark. Some quick futzing around may have adjusted that for me visually, and created a bit of better smoothness to the flow of the logo.
It's subtle, but it changes it a lot to your eye... it may even show smoother with the left base of the S extended a TOUCH further, too.
Arlo Kalon 2.0
I see immediately the perception of that "left side" difference you mentioned. I'm intrigued by the difference such a small change makes, and I see the possible appropriateness of both left edges of the 2 combined letters being lined up evenly. I'm sure I'll be staring at the printout all day trying to decide! My 1st thought is that the kicked out appearance of the outline now in the lower left side creates a visual hot spot? Or... is it reinforcing the perception of the 2 letters - and was there a problem to begin with perceiving the 2 letters immediately? I'm absolutely open to opinions on this - if I bring it back, I want it to be the best!
sign chick
"Timeless" was exactly what I thought when I saw it. 20 years ago? Awesome! I've kept my most recent one for 3 years and working on changing it.
I like Doug's changes. Very subtle but makes a difference.
Arlo Kalon 2.0
3D sketch idea
Still toying with using this logo again... haven't tried suggested revisions but I am going to. For now, here is the 3D program "metal" surface idea.
ApexSpeed
Dave, honestly, I'd highly recommend staying away from graphic gimmicks like metal, diamond plate, marble textures and stuff like that. It just detracts from the simplicity and elegance of the original logo.
To me, when stuff like that is used, it looks like it is just trying to hide a bad logo under fancy clothes... kind of like puttin' purfume on a skunk, so to speak. Those P-shop-like stunts just make it hard to read and harder to reproduce in any printed manner.
2¢ again.
doug
Rick
Purfume on a skunk? My favorite 2 are Lipstick on a Pig and Polishing a turd.
I'm not calling it a turd or a pig, but I agree with Apex, this type of photoshop trickery is like wearing a 80's Velvet Tuxedo, it has it's time and place, but very very rarely used. Simple simple simple...plus we see the logo, what about the type that goes with it and how it's related to the logo. We re only seeing part of the picture. I would also do the adjustments before you add color.
Arlo Kalon 2.0
Actually, I don't ever use Photoshop - this was part of attempts to create a 3D aspect and was done in a high end program called IronCad. I'm looking for a metal appearance with a hint of some depth. Also, I at times think we must be the only profession that forms a core group of concepts and holds to them forever without updating our opinions. What I mean is simply this: IF the output devices and choices available today were on the scene when the "rules" of composition were evolving, I don't think we'd still be holding to the notion that a logo has to be simple and has to work in B&W before you can do anything else with it. I'm looking for a representation of this logo specifically to do on the Edge, and for a "look" I'll keep for years - even tho with a mouse click I could change it. One thing I learned in the radically custom atmosphere of a motorcycle factory paint shop was that there are a LOT of business owners wanting to do very radical appearance ideas to their logos. And I don't mean just the guys who ordered custom choppers that carried their business branding. Our design dept was often asked to create sign layouts by people who worked with us on creating their custom cycle graphics. Since they could see we had everything that sign shops had, they took advantage of the opportunity to completely redo their entire appearance. This was one of the reasons I decided to go back into sign work - as long as I was doing it with digital printing in the mix! I know that the type of Edge output look I'm after won't "fit" everybody, but for that very large pool I saw that DID want this type of appearance, I am narrowing my focus to working as exclusively for them as I can. The last thing they'd expect me to do is a simple treatment of my own graphics. And, I do have the rest of the lettering to go with the logo, just haven't tweaked it enuff yet to include an example of it. Anyway, I admit it IS against my old signpainter grain to do this for my own sign work, but like I said - the customers I want would expect it from me! Hope this helps explain where I'm going with this and why.
Rick
I think the motorcycle, ratrod, chopper look is overdone rehashed stuff, I know, I am a big fan of the movement, but there is a lot of bad stuff out there. As far as holding to a group is concepts, I am first a graphic designer, and do work way beyond signage...signage just happens to be my first love, sites like www.bd4d.com, www.stencilrevolution.com, www.lounge72.com, www.core77.com pushes that limit, so I understand the idea. The client see's what is successfull and usually comes off as a knock off of what was done before. As far as the "output device" idea. I don't buy into that too much. I remember getting my copy of Photoshop when it came out and the first thing I did was do every trick in the book, I know from experience what you showed us. If you look at graphics done by newbies with Photoshop, they have this same look, so much so that when done right, still looks cheap. Just because an output device can do it, doesn't mean it should be done...again, shiny 4 color cards are done to death by lowend graphic designers, it has it's place, but this this huge divide that most are not willing to see.
Same with websites, flash heavy chopper sites and customizers that are mostly knock-off's of the others. To me graphic design should be a little more innovative while keeping to a proven process.
As far as IronCad, I have never heard of the program, (I did look it up, pretty much the same as Auto-Cad or Form-Z) but your treatment could have easily have been done in Photoshop.
I do understand your thinking on this, and the customer is used to seeing the competitions "look" and they want that. I just think there needs to be someone to break it away from the current re-used look.
Arlo Kalon 2.0
You are so right...."just because a device can do it, doesn't mean it should be done" - this is the bane of so much technology as far as I'm concerned. And it (technology) is also the entry point for so many unskilled people to grab a piece of software, print up business cards, and call themselves whatever type of profession they want to be. Nothing is ever going to change that again. However, I have narrowed my focus to a specific mindset customer - I can afford the luxury. I won't fret over whether what he wants is something I should do or not - I no longer possess that level of youthful idealism, although to be sure I did my share in the past to try and educate customers in order to avoid doing a "knock off of what was done before". I'm simply immersing myself and my efforts into what I've seen get enthusiastic response and fantastic financial rewards for the past 4 years. And, as opportunities present, "innovate" where I can - as I've always done. It really is more of a concept that I am the one who is the wrong fit for the vast majority of available customers - I just don't want what USED to be my bread and butter work when I was in business before... because my bread and butter is a done deal at this point. Even if it wasn't tho, I'm convinced there are enough people out there who want whatever version of a rehashed custom formula with a proven track record that anybody could make a go of catering to them. I, like most people in this business I know, have been the one size fits all type of business... I just couldn't go back into it thinking like that. As for my mentioning IronCad... it's just a tool I've found to be rather amazing for creating work to exploit the potential of Edge printing. It isn't of course anything at all like Photoshop - which I have right beside it - but Photoshop can not actually do the effects I utilize a 3D tool for - unless nobody looks very closely (which of course nobody does, so I sure as heck don't recommend plopping down 2 grand for a high end 3d/cad program. I just wanted it, a toy I guess!). Thanks, as always for the input and ideas! Where would we be without a stream of ideas?
Rick
I hear you Dave and great response, I am a little older myself, so I understand your comments, nothing I have not heard before.
By the way, I knew that Photoshop can't do 3D, but it could have made that image you presented, of course you couldn't manipulate it at different angles. But it can make metal images, simulated bevels and texture your image has...if you want an isometric view, well there you need the 3D program.....
