I am getting code 0109, but only when doing a 'powerful' cleaning. will do a regular or medium without issue.
Quick recent history:
Most of my inks drained out of my printer, it stared with just one colour, so I thought it was wicking out but then all but cyan drained out. Figured it was the ink pump, so I replaced the ink pump and the cap tops just incase. Unfortunately it sat for 10-15 days with no ink in those lines/heads.... I was hoping that running a few cleanings would get things flowing, but it didnt, so I pulled off the dampers and suctioned with a syringe and then tried to follow it with a cleaning... regular cleanings and medium cleanings work fine, but the powerful cleanings come up with the 0109 code. I think that has something to do with the wipers, but I wasn't sure if that might be happening because the heads are a bit dried up... can that cause it?
Should I do a head soak and see what happens? should I be replacing the wipers? Help! Thanks
