Need Help machine has stopped heating mimaki jv3
Robson miranda
Hello everyone, my machine has stopped heating but there is no error on the panel, the drying fans have also stopped can you help me the equipment is a mimaki jv3 160
Ícone Verificada pela comunidade
Forty One
Mike. Thanks for sharing that you don't speak Portuguese.
"Hello everyone, my machine has stopped heating but there is no error on the panel, the drying fans have also stopped can you help me the equipment is a mimaki jv3 160"
Robson, Verifique todos os fusíveis do painel de alimentação até o painel que controla o aquecedor e os ventiladores.
Caso contrário, verifique os cabos etc.
Everyone else...
Check the fuses on the powerboard to the board that controls the heater and fans.
Failing that, check the cables etc.
MikePro
pretty sure that this is the first thread on this forum with portuguese.... especially with an english subject header, but hopefully you're available to translate for us once espanol threads start stacking up. appreciate the edited post, Robson.
cables & fuses, easily traced from fans & heater back to the board & power supply to find the gremlin under the hood.
kerwinchua
Production Manager
Everyone else...
Hi, just replace one of the plugs. There are two power sources. One is for the electronics, while the other is for the heater and fan :)
let me know if this works!
sometimes the power source for one of the plugs may have tripped a breaker or something.
