Magazine Room
Andrew Hodgson
My client is looking to do a magazine room. In the past, we have done several pieces of clear Plexi next to each other. my client did not like the seam in the middle. Is there a different clear rollable material I can use instead of a clear rigid board?
JBurton
Signtologist
You should be able to get your hands on polycarbonate up to 100" wide, if not even wider.
As far as something you could roll up, again, poly, but they do make much thinner poly that is about .02" thick, but I highly doubt it's available in a width over 4' or so.
Andrew Hodgson
Perfect! I totally forgot about that, I think that's the best solution for the price.
Andrew Hodgson
Now that that's solved.... What is a magazine room?
A room where several people are able to walk into. The front of the room is supposed to look like a magazine cover with the people inside the room being the subject. We print text and other graphics onto the clear front window. I think I attached a photo of this in the original post. I have used these as photo ops for events.
Yeah, that seam is a little overboard. Why can't you get them to be basically seamless looking ??
