Click to Support Signs101 ...
What's the best way to make a magnetic dry erase board? We currently make dry erase boards that are non-magnetic with pvc, vinyl graphics and a dry erase laminate. We do a lot of boards that are 4' by 8' and want to start offering the magnetic option.
What I do is buy galvanized sheet metal from a heating mechanical supplier and coat it in the printed grid with the laminate.
You can then adhere the sheet to another substrate for rigidity.
Look into Pre coated or pre painted sheet steel. It can usually be found in a variety of gauges and sheet sizes from your nearest sheet metal supplier. Some suppliers have it in rolls (ColorCoil) and will shear what you need. You can laminate it to whatever substrate you desire, typically using a contact adhesive. 22 gauge is desirable, however, as thin as 30 ga. is also available. You will want to remember that the thinner the gauge...the less steel there is for the magnets to hold onto.
