You are not going to get the exact measurements of a
sign based off a photo. There is always some distortion from the lens and settings used to take the photo.
You can get close
To get your base scale set up you need to know the actual size of something in the photo. If you have this you should be golden.
Find the longest horizontal or vertical edge in the photo and use "Deskew" option under the "Arrange" tab to rotate the photo square with your screen.
From there you can draw a rectangle around the object in the photo that you know the size of - use it to mask the photo inside and then scale up your rectangle to the known size - unmask and set a new rectangle around the edges of the
sign to give you the rough size.
Again there is always some distortion and you should physically measure the
sign on site if fitting is critical.
wayne k
guam usa
