cobo_design
Imaginative art ga
Hi everyone,
I'm hoping someone (especially Solventinkjet or Smoke_Jaguar) can help me troubleshoot a very strange issue on my Mimaki JV150-130 (DX7).
I've been chasing this problem for several days and I'm running out of ideas.
I've attached nozzle checks, photos and a video of the cleaning cycle.
PD. In the attached printhead photo, there appears to be a buildup of dried magenta ink on the magenta side of the nozzle plate. It almost looks like the ink is drying or accumulating in that area. I'm not sure if this is normal or if it could indicate poor capping, ink misting during cleaning, or an internal pressure issue.
Does the magenta buildup on the nozzle plate suggest poor capping, ink misting, a manifold issue, or an internal head failure?
Any ideas would be greatly appreciated.
Here's the link for the video:
Symptoms
- Only the right half of the Magenta nozzle bank drops out.
- The missing nozzles are always in the same area.
- The printer can print perfectly for an entire day with no banding or missing nozzles.
- The problem usually appears after the printer has been sitting idle or after the automatic power-off (30 minutes).
- Sometimes a Normal Fill Up Ink brings the magenta back to 100%, but other times it doesn't recover at all.
- During a Normal Cleaning, I can actually see the magenta firing normally at first, but after a second or two the right half changes from a normal stream into a very fine mist/spray.
Things already replaced or checked
- New DX7 printhead (approximately 1 year old).
- New cap top (aftermarket).
- New pump.
- New dampers.
- Flat cables disconnected, cleaned and reinstalled.
- Cap position adjusted.
- Cap height adjusted.
- Air Pull Position adjusted.
- Several Normal, Hard and Ultra cleanings.
- Fill Up Ink.
- Overnight nozzle soak with cleaning solution.
Additional observations
- If I push cleaning solution through the magenta inlet with a syringe, fluid comes out of all nozzles, so the nozzle plate doesn't appear to be completely clogged.
- Moving the Capping Position actually improved the nozzle test, which makes me think the problem could still be related to capping or pressure.
- After printing continuously for hours, the nozzle test becomes almost perfect.
- After the printer sits overnight or powers itself off, the magenta drops out again.
My questions
- Could this still be a capping station alignment / cap slider issue even though the cap seals well?
- Could a cracked manifold or manifold O-ring create these symptoms?
- Has anyone seen a DX7 where the head prints perfectly while running but loses half of one color only after sitting idle?
- Does the mist during the cleaning cycle point more toward a pressure problem, manifold issue or an internal head failure?
