Mimaki Print Quality
Signman Jay
Does anyone know what would cause my JV300 Plus to do this? Cleaning and loading the ink doesn't fix it and I replaced the cap 20260504_162917.jpg
Smoke_Jaguar
Check cap alignment, dampers are a cheap(ish) consumable that tends to wear out and cause ink starvation. Could be a head issue, but best to start with the low hanging stuff. Also, not a bad idea to swap the waste ink pump if you haven't already.
peiton
Aveces hacer muchas limpiezas también daña el cabezal lo más recomendable es que un técnico mimaki te explique y corrija en daño en tu cabezal te lo digo por experiencia propia dónde trabajo hay una ujv 100 160 plus y evitamos hacer limpiezas cuando salen los test así para evitar dañar el cabezal prueba cambiando el capim y los dampers que hay puede estar la falla
dercar
I’m afraid, my friend, you may have a problem with the pump.
Either one of the tubes is clogged, or the pump has stopped pulling properly, for example because a tube inside it has split. You can see it from the way your colors are mixing, which should not happen.
And since the cap is not being cleaned properly, your nozzles are probably just contaminated. The head is still firing and spitting ink drops, but the drops cannot get through the dirt cleanly, so they spray around instead.
I would also replace the wiper. Or at least inspect it very carefully.
Jungteam
The fastest and most effective approach is to proactively replace your consumables—specifically the damper, cap top, motor pump, or the motor pump tubing—with brand-new parts.
It is very common for a printer to run flawlessly for a long time after installation, only for issues to emerge later. Over time, you might find that the nozzle cleaning cycles become less effective, or that it takes a frustratingly long time for the nozzles to recover.
When you hit this stage, swapping out these key maintenance parts first is always the quickest path to diagnosing and resolving the underlying issue.
While the exact model might differ, almost all printers in this class share a nearly identical mechanical and operating principle. With that in mind, I am attaching a comprehensive series on ink delivery and cleaning issues below.
Taking the time to review and study these guides thoroughly should make troubleshooting and resolving your current issue much easier: https://artjetech.com/printer-cleaning-problems-part-23-table-of-contents/
